What about the usage/longevity issue that I see raised here and there with HELICOILs. Those bolts are holding the exhaust bracket so there's a strong possibility that they'll be removed every now and again.
So my measurement should be minus an 1/8" to get the proper length bolt?
If the insert is 3/4" long then you don't gain anything from using a bolt that goes in more than about one thread past the end of the insert. If the hole is 1-1/2" deep you don't run much chance of bottoming out.
Don't forget that the Timesert will sit proud of the surface of the part by the thickness of the flange. I would think if you're mounting an exhaust bracket that would be undesirable.
Heli-coils shouldn't pull out if properly installed. We use them in aircraft spark plug holes and the plugs are pulled at least once a year for inspection.
22 ft-lbs on a bolt that is bottomed out puts a whole different load on the threads than 22 ft-lbs on a bolt that's clamping something (and stretching the bolt.)
I believe those screws are 5/16 x 18.. Technically for popper torquing and clamping force with any bolt you would need to get one and a half times the diameter of the bolt thread into it's fixture. Using a longer bolt will not aid in clamping/torquing force..
So 1.5 x 5/16 = 15/32 .. So on a 5/16 x 18 screw that would be roughly 9 threads to safely reach the max torque of that fastener..
OP, I'm not a big fan of inserts, unless there is absolutely no other alternative. Since you have a full inch and a half of material to thread, what are the chances of utilizing a "non-traditional" size to drill/tap new threads? Is there enough material internally to support thread strength for this purpose? This would be the deciding factor, on whether to use inserts or not.
One other factor to consider.... some of these holes support a vibrating exhaust system. This could mean "excessive wrenching." These threads are going to have to withstand that, also.
Might even suggest a non-permanent thread locker....
Factor this into your methods .
Reason: Add'l info
There is enough material on the transmission case, but the bolt head size is limited by the main bearing carrier...and my OCD would never allow different size heads anyhow. I'd go buy a whole new transmission case before that happened.
Well, after watching the new video @Max Headflow posted and drinking about it last night while watching more videos, I am going to go with the Heli-Coil. Bonus, I already have a kit I bought a couple of years ago to do this job. The race puller showed up this morning and I might have time to get out to the shop after getting some work done. I really appreciate all the good input guys; I've learned a lot.
That was really interesting. I'm in the category that's been lead to believe that time-serts were by far the superior choice, and maybe in some instances they are, but this video shows otherwise.
I'd heard that also even tho I've not used them but have used Helicoils a lot and some keenserts. The main reason for keenserts was that the hole was so buggered up that a helicoil wouldn't work.
I wonder if it's the fact that there is some clearance between the timesert insert and the hole.. Helicoils wind in and have tension on the hole for max bite.
