case repair completed
Old Dec 15, 2024 | 04:08 PM
GFastng's Avatar
GFastng
Default case repair completed
Hello everybody, hope everyone had a nice weekend. Today I trailered my, "New to me" '06 Wide Glide to my Uncle's house where he has a welding shop.
This is the, original post when I discovered it here
Below are some before, and in progress photos of the repair and one with the repair as it sits right now. upon completion, there was a tap run through some of the offending holes to ensure they are now cleared.
Old Dec 15, 2024 | 05:14 PM
WP50's Avatar
WP50
Nice job Sir
WP
Old Dec 15, 2024 | 05:31 PM
GFastng's Avatar
GFastng
Originally Posted by WP50
Nice job Sir
WP
Thank you, but I cannot tke credit for the weld, I can only claim responsibility for knowing who can do the job right.
Old Dec 15, 2024 | 08:49 PM
Max Headflow's Avatar
Max Headflow
Are you going to replace the trap door bearings?
Old Dec 15, 2024 | 10:21 PM
robarosa's Avatar
robarosa
Real nice job. Good to have an Uncle like that.
Old Dec 16, 2024 | 02:54 AM
GFastng's Avatar
GFastng
I might, going to give them a good look the next day or so.
Old Dec 16, 2024 | 05:57 AM
Jackie Paper's Avatar
Jackie Paper
Nice. Your Uncle knows his stuff. Welding cast aluminum is tricky. Heat moves stuff around and it doesn't come or go back.
I would dry fit that cover back on without a gasket to see how flat that surface is. Make sure it doesn't rock and finger tighten it and check for any drastic short length gaps with a .002 feeler gage.
May need to use a film of Permetex RTV black on both sides of the gasket now.
Just a film so none gets loose inside. I snug up and let it dry before rolling that fine hair thin bead you may see off the seam.
Old Dec 16, 2024 | 08:03 AM
Max Headflow
I'd replace them.. I pulled the trap door on a 5 speed that way and 20000 miles later both went bad. IIRC the 6 speeds may have deeper groove bearing to handle the axial thrusts but depending on how you RnR the plate you can damage them..
Old Dec 16, 2024 | 09:43 AM
John CC's Avatar
John CC
Everyone should have an uncle like yours!
Old Dec 16, 2024 | 11:01 AM
470004's Avatar
470004
Your uncle did a great job.
