Lithium Batteries
Old Feb 7, 2025 | 06:09 PM
small country's Avatar
small country
3rd Gear
Default Lithium Batteries
Got a question Guys.
I have a 2000 Dyna and wanted to change my Battery to Lithium. Is it compatible with an older charging system? Do I need to do anything to accommodate Lithium batteries?
Old Feb 7, 2025 | 08:03 PM
Rocking_it's Avatar
Rocking_it
Old Feb 7, 2025 | 08:05 PM
TriGeezer's Avatar
TriGeezer
Get a chemical fire extinguisher, and asbestos underwear.
Old Feb 8, 2025 | 04:25 AM
RANGER73's Avatar
RANGER73
To answer your question, no.
Lithium batteries require a Lithium tender.
Old Feb 8, 2025 | 04:30 AM
NorthWestern's Avatar
NorthWestern
For a LiFePO4 battery?
Old Feb 8, 2025 | 05:32 AM
MURPHCC1's Avatar
MURPHCC1
LiFePO4 battery for 3 years now, pants are not on fire. Bike starts GREAT!
Comes with a special battery tender just for lithium. They are different than acid battery tenders.
Old Feb 8, 2025 | 06:15 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Are you asking about a tender or are you asking if your bikes charging system is compatible?
Old Feb 8, 2025 | 06:39 AM
702's Avatar
702
Some people have had great luck with them and some have had a bad luck with them. My experience was bad on a 22 Heritage. I wouldn't run one again if you gave it to me.
Old Feb 8, 2025 | 08:15 AM
small country
3rd Gear
Yes. The Lithium battery itself has all kinds of overload protection. The one I was considering does not clearly state it need s a tender but I get the feeling I would need one. Which I don't mind using a tender if it's required but is the Lithium battery still safe to be connected to the Bike? What is the charging system doing at that point when it's running?
Old Feb 8, 2025 | 08:43 AM
MURPHCC1's Avatar
MURPHCC1
LiFePO4 battery are protected internally with all kinds of electronic wizardry.
I've never used the tender even after not riding for two weeks on my Ultra, started right up.
My battery has a voltage read out right on the battery so you can see what's going on with it.
Attaching a tender does what it's supposed to do, maintain voltage. not rocket surgery.
