Stop Lights
Old Sep 5, 2007 | 08:16 AM
2007fxdc's Avatar
2007fxdc
Default RE: Stop Lights
Well I've learned a new trick or two to try from this thread. I had this issue just last night as a matter of fact. I did recently read about legislation here in NC specific to this and yes it did die due to some ridiculous technicality. However, as someone else suggested, I do wait about a minute and, if the coast is clear, proceed on through. And, I will take it to court if I get ticketed on it. We can stop and turn right on red in NC if the traffic is clear but we can't go straight - go figure. With that said, I guess that's another option - if the light won't change, make a legal right turn and re-route. Of course, none of that helps if you are trying to cross a busy road that never lets up enough to make a safe crossing with the light still red - especially if the road you are on is way less traveled andnobody shows up behind you or across from you in a reasonable amount of time.
I'm going to try the jiffy stand trick next time. I didn't realize those things were magnetic - I've always thought they were triggered by weight somehow.
Old Sep 5, 2007 | 10:18 AM
Wide Glide 05's Avatar
Wide Glide 05
I wonder if steel toed boots would trip the light? I was at a light recently that would not change so I took my boots and moved them around a little and the light changed.
Old Sep 5, 2007 | 11:12 AM
JRK5892's Avatar
JRK5892
WHO STOPS AT LIGHTS???? we have to stop at those.... they are not just a sugestion.... $#%@ i knew i should have paid attention in drivers ed
Old Sep 5, 2007 | 11:13 AM
GaryInSanDiego's Avatar
GaryInSanDiego
The most important factor is the position of the rims relative to the sensor. The rims are the closest metal to the road. Try to run over the tar sealer outline of the loops and stop with your rim on top of one of them or just slightly to the inside of the loop. That's where the magnetic flux density is greatest. If the road has been paved since the loops have been installed, you have to guess.
Gary
Old Sep 5, 2007 | 11:53 AM
Visionquest's Avatar
Visionquest
Hadn't considered the rim factor before, thats interesting. My sporty won't trip many of the lights, but my Super has no problem, both are laced, the SG just has 80 on each wheel. Must be enough of a difference.
Old Sep 5, 2007 | 10:18 PM
rbtwhiz's Avatar
rbtwhiz
ORIGINAL: Wyde Glyde Bry
Got a pic of this thing under your bike?
I hope it's not this big red canister they display on the website.
When I bought mine (a year or so ago?), they didn't have the '...is best for these types of vehichles'images on the website. In all honesty, I don't think the newer one, the G-42, was even available yet. Regardless, Ihave the SS-1, not the G-42. The thing is smaller than one of those little sticks of gum; i.e. classic dentine, orbit orthe like. There is a picture on the installation page, as well as on the top of the product page. The newer one, judging from the dimensions onthe product page (4†x 1†x .375") iscomparable toa pack of [stick] gum; i.e. wrigley's spearmint.
Old Sep 6, 2007 | 02:47 AM
20LowRider02's Avatar
20LowRider02
I can't get out of my apartment complex!! I have to wait for a car to come either in or out. That's a pain at 4am when you're going for an early morning ride!!
Old Sep 6, 2007 | 05:30 AM
Psycho's Avatar
Psycho
ORIGINAL: Dan94509
Dose anyone have a problem with stop lights that won't change! [:@]
I don't know any tricks. Here in tennessee, we just run them if they won't change. I don't know the legalities from state to state, and just take my chances when in other states.
Old Sep 6, 2007 | 06:56 AM
2007fxdc's Avatar
2007fxdc
Update on the NC law a couple of us mentioned earlier in this post. According to the August issue of Full Throttle magazine, the bill has finally passed both sides of the General Assembly and, unless the governor decides to nix it between now and then, it should go into effect December 1, 2007 allowing bikes to pass through a red light once they have come to a complete stop and checked traffic - basically treating a red light as if it were a 4-way stop.
Old Sep 7, 2007 | 11:03 AM
ReAnim8or's Avatar
ReAnim8or
4th Gear
Try turning off the bike and then starting it back up again. Power to the starter should be enough to trigger the sensor.
--ReAnim8or
