2016 O2 Sensors
I took the stock exhaust off and installed a Bassani 2 into 1, so I will need a tune. Before getting a tune, I wanted to replace the O2 sensors, for good measure. I replaced the rear sensor no problem. As I'm looking at the wire routing for the front sensor, I notice it plugs into the harness just below the horn. Out of curiosity, I traced the harness wire back and up under the seat where I found it simply plugged off with a plastic cap. To confirm I traced the correct wires, I did a continuity test. Yep that's correct. The front O2 sensor is simply capped off with a plastic cap. See photo. I don't see a a vacant receiving end anywhere that it should be plugged in to.
Why would this be? Would it be something the factory did? Or, during performance mods.... did the previous owner do this? Either way, I find it hard to believe that any computer controlled bike wouldn't want to read the front cylinder. Thoughts?
Based on the sticker on the inside of the cover, I believe he had this tuner.
https://store.thunder-max.com/collec...a%C2%AE-models
It does appear this tuner has two sensors. I just don't see where the factory second sensor plug is.
If that is in fact what is on your bike, that is not a tuner, per say, it is a replacement ECM for the OEM ECM. It has it's own O2 sensors, and doesn't use the OEM O2 sensors or O2 sensor wiring. It is customer programable, so it's basically a new ECM that you can then tune easily. If you have that ECM, get the manual from Thundermax. Read about what it can do. Read the install portion, and it will tell you what and where OEM O2 sensors will be unplugged and/or capped.
An actual "tuner" is either a piggyback style tuner or a flash tuner.
A piggyback tuner plugs between the original ECM and the sensors, and it fools the ECM into making changes to the bike's tune.
A Flash tuner connects to the bike via the data port. It can then read and write to the OEM ECM. It can adjust or totally replace the OEM tune, and other parameters. Then it is disconnected and your bike works off the OEM ECM and sensors, with the changes that were made to tune.
I use a PV and haven't ever used the Thundermax so I don't know if it permanently owns the ECM like the PV....so I wonder if it's possible to now use a PV on it?
Also, was the exhaust the only thing the PO did or does it have a different cam than the stocker?
Today I had the battery out, and I pulled the ECM and the entire wiring harness out. It's as if this bike came with the provision to plug in only one O2 sensor. Maybe the FXDLS came this way. I don't know.
