Forward control questions
Old Mar 18, 2025 | 07:32 PM
John CC's Avatar
John CC
Maybe you can buy the peg from TC Bros and adapt it to your brake lever, or find an aftermarket peg only. You'd have to cut the tab off the current pad is connected to, and drill a hole for the new peg.
$35.99
Old Mar 18, 2025 | 07:46 PM
Fancierdoughnut's Avatar
Fancierdoughnut
$35.99
I'm considering doing that or leave it be and just replace the pad on the stock lever
Old Mar 19, 2025 | 06:19 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Originally Posted by upflying
Maybe the Street Bob has what you are looking for.
2014 HARLEY FXDB DYNA STREET BOB RIGHT FORWARD CONTROL BRAKE PEDAL HD3 ...
Looks like Upflying posted a good option back up there in post #5.
Old Mar 19, 2025 | 06:20 AM
RANGER73's Avatar
RANGER73
There are usually sets that include all the matching pieces.
Old Mar 19, 2025 | 09:22 AM
Fancierdoughnut
If I had to buy a set, it will probably be one of these two depending if i wanted to go with black pegs or silver:
Old Mar 19, 2025 | 08:25 PM
RANGER73's Avatar
RANGER73
[QUOTE=Fancierdoughnut;21973304]If I had to buy a set, it will probably be one of these two depending if i wanted to go with black pegs or silver:
I meant peg sets, you don't have to buy new forward controls.
Unless I missed something?
Old Mar 19, 2025 | 08:39 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The bushings in the toe shift lever may be worn and giving a bit of slop. Brake lever bushings part number 4262-00A, that's what I used on my 02 SuperGlide to fix the slop and rattle.
Old Mar 19, 2025 | 11:23 PM
Fancierdoughnut
[QUOTE=RANGER73;21973930]
Brake lever has a 90⁰ bent and pad mounts differently than the toe shifter, so to have matching pegs, I'd have to modify the brake arm
Old Mar 19, 2025 | 11:24 PM
Fancierdoughnut
Same bushing for brake AND shift lever? I'll have to look into it
Old Mar 20, 2025 | 05:25 AM
RANGER73's Avatar
RANGER73
There's a reason the brake is a pad and not a peg.
Less of a chance that your foot slips off.
