2008 Dyna Fat Bob vibration problems
Old Apr 16, 2025 | 09:05 AM
Pedro Amado's Avatar
Pedro Amado
5th Gear
Default 2008 Dyna Fat Bob vibration problems
So, A few weeks ago I posted about vibration after changing the mufflers. Bad vibration started that wouldn't allow me to ride in peace. the foot pegs vibration numbed my feet and the mirrors were completely useless.
Changed the exhaust again, torqued and retorqued the mount bolts and when I released some torque of the exhaus mount that is bolted to the frame and gearbox, and the vibration is gone.
Now, the question is: Can I keep those bolts without the proper tightening torque? what is the risk? should I use some rubber washers to try to reduce the vibration?
I'm completely lost and in the meatime, one of the bolts broke and I need to use those extractor tools to extract it. Also read somewhere that these bolts break often, maybe due to vibrations...
All comments welcome.
Thanks.
Old Apr 16, 2025 | 09:09 AM
pgrchaplain's Avatar
pgrchaplain
I'd check the Motor Mounts to start with. You can't leave the Exhaust Mounts loose. Google Switchback Clevis Pin Fix, you may try something like that.
Old Apr 16, 2025 | 12:41 PM
Pedro Amado
5th Gear
The mounts are new. I mean 2 weeks new and they were destroyed before.
I don’t mean to have them loose, I mean to leave them slightly less tight than the 24Nm Harley’s manual recommends.
Engine is rubber mounted and vibrates without affecting chassis but the exhaust vibrates and is directly mounted on the chassis. Doesn’t make sense to me.
Maybe some washers with rubber “lining” could help and I could tighten the bolts a bit more while avoiding vibration or blue loctite the bolts.
Old Apr 16, 2025 | 09:08 PM
John CC's Avatar
John CC
It shouldn't be! It should be fastened to a bracket that attaches to the transmission. If it is really connected to the chassis it will break in short order.
Old Apr 17, 2025 | 06:47 AM
Bubba Zanetti's Avatar
Bubba Zanetti
A pic of the exhaust and the mounts would help.
Razorback Rob
Aug 28, 2014 06:16 PM
Yosemite
Apr 4, 2012 10:24 AM
labou1
Jul 25, 2011 09:05 PM
Rocket350
Sep 7, 2007 07:34 AM
tominokla
Aug 17, 2007 09:16 PM
