Twin cam sputtering
Old Apr 28, 2025 | 03:08 PM
Max Headflow's Avatar
Max Headflow
Clean the ET sensor connectors and pins on the sensor. tug on the wires going into the connector.
Old Apr 28, 2025 | 08:17 PM
John CC's Avatar
John CC
And check the resistance against the ambient temperature.
Old May 3, 2025 | 07:32 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
there was a TSB issued during the 2006/2007 years that changed the injectors from 6 degree to 8 degree.type. The 8 degrees would give a better flow and spray pattern. Maybe a dealer could help out for this TSB notice.
Old May 3, 2025 | 10:25 PM
hattitude's Avatar
hattitude
Did you mean the service bulletin for changing the 8° injectors for 25° injectors on Big Twin 1450cc engines?
I have a .pdf of Service Bulletin, M-1185, Dated Feb 20, 2006 titled: Fuel Injector/Calibration Changes for 2006 1450cc Big Twins:
"Motorcycles AffectedOnly 2006 1450cc Big Twin model motorcycles that exhibit cold start and/or driveability problems directly related to use of 8 ̊ angle cone spray fuel injectors (including those subse- quently equipped with P&A Screamin’ Eagle 1450cc or 1550cc Performance Kits)."
The dealer action , #3 read:
"If required, remove both 8 ̊ angle cone spray fuel injectors following the procedure in the applicable 2006 Service Manual. Install 25 ̊ fuel injectors, either part number 27709-06 or 27709-06A."
I haven't been following this thread, but if somebody believes this Service bulletin is applicable, I could post both full pages in this thread.
Old May 4, 2025 | 07:13 PM
seniorsuperglideE8
Thanks for correction, that looks more familiar.
Old May 5, 2025 | 04:12 AM
cycle_man's Avatar
cycle_man
Default 06 Wide Glide
Mine had the same problem. I am not sure about yours but mine had the early model 06 fuel injectors. There is a bulletin about the early model 06. Of course no one wants to fix them for free so I bought the newer ones and replaced them myself. Big difference in power and no misfire.
Old Jun 7, 2025 | 06:13 AM
joeydyna's Avatar
joeydyna
Sounds like it's an injector issue. I replaced the ET sensor and codes went away. Still having the same issues in the 2300-3200 rpm range. I also recorded a datalog since I had a tune put in recently and im waiting for that to be updated but in the meantime maybe I'll try injectors! Thanks for the help
Old Jun 7, 2025 | 06:11 PM
Lonewolf176's Avatar
Lonewolf176
The issue start with the new tune?
Old Jun 7, 2025 | 06:37 PM
joeydyna's Avatar
joeydyna
honestly I can’t remember. I had sold it to a friend, bought it back and had new exhaust and intake put on and tuned it shortly after with little seat time. My buddy who had it didn’t seem to notice anything hot I do vaguely remember asking him about it when I first got it back and he didn’t notice anything. It’s possible it was worse after the tune but I really can’t remember
TPost
Twin Cam Motors
24
Jan 14, 2024 01:51 PM
02fx
Sep 17, 2022 07:41 PM
euchre98
Milwaukee Eight (M8)
Aug 20, 2022 08:00 PM
32roadking
Nov 2, 2008 04:27 PM
HDF Tech
Engine Mechanical Topics
Jul 2, 2005 03:19 PM
