Slow crank on cold start - 2015 FXDL
Old Jan 13, 2026 | 08:47 PM
John CC's Avatar
John CC
Originally Posted by baba booey
That seems to me an odd behavior of a “good” battery.
Depends... Where exactly were you measuring the 5-6 volts while cranking?
Old Jan 13, 2026 | 10:05 PM
baba booey's Avatar
baba booey
the battery terminals.
Old Jan 13, 2026 | 10:23 PM
NorthWestern's Avatar
NorthWestern
Put a new battery in it.
Old Jan 14, 2026 | 08:58 AM
Weeboy1's Avatar
Weeboy1
Two learned members above are trying to help!
Stop dicking around and replace your tired battery.
Old Jan 14, 2026 | 09:24 AM
Jackie Paper's Avatar
Jackie Paper
Originally Posted by Jackie Paper
Get a new battery and charge it on the maintenance charger before trying it
That could mean the battery is toast, or it could also mean the starter is drawing to much current (also toast). Did the voltage continue to drop the longer you cranked?
If you have access to another battery, or can safely jump it, does it crank OK?
The last thing to suspect when having cranking issues is the starter, and swapping out starters is not troubleshooting, no matter what Google AI says.
@baba booey You need a new battery.
?? A few more than two.. And when DAN says to do it, that settles it.
Old Jan 14, 2026 | 01:45 PM
Weeboy1's Avatar
Weeboy1
Sorry I didn’t credit you, couldn’t read em all but the point is made…I guess.
Old Jan 14, 2026 | 03:28 PM
baba booey's Avatar
baba booey
will do.
Several others recommended doing other diagnostic tests so I’ve been working through those as well.
Old Jan 14, 2026 | 04:19 PM
Rounders's Avatar
Rounders
I would try jump box again. But if battery is really bad some models wont work.
Who just has a known good starter laying around?
How many miles?
It is 10 years old, which is not old. Cables would be last thing I worry about or even connections,at least in my part of the country.
Has the engine been modded? Did it come with automatic compression releases?
Slow starts are normally batteries. But you replaced it with factory. But sure wonder about battery
Old Jan 14, 2026 | 04:30 PM
baba booey's Avatar
baba booey
How many miles?
the battery is at least 2 years old. Bought the bike used two years ago. No engine modifications at all.
I assume it has the factory automatic compression releases.
as suggested earlier I’m going to replace the battery.
13000 miles.
Old Jan 14, 2026 | 05:42 PM
Rounders's Avatar
Rounders
If it came with the battery in there and is starting slow,I would not waste to much time. I understand batteries are expensive .
