engine warning light and red warning light.
Old Apr 26, 2026 | 06:46 PM
John CC's Avatar
John CC
If I am remembering that wrong, I welcome the correction.
Nope, right on all counts. The bushing can cause the brake light to stay on, and there's no adjustment for the switch. Be careful moving the lever around as you can break the switch otherwise.
Old Apr 26, 2026 | 09:56 PM
snoozy's Avatar
snoozy
Thanks for the detail, will look into this.
Old Apr 27, 2026 | 12:08 AM
snoozy's Avatar
snoozy
Took the brake lever apart, the pivot pin bushing seems fine, but it does have a little play in it, is the pin supposed to slide in snug? Might order a new one anyway.
Also tried this:
Exact same symptoms I'm experiencing.
Followed his procedure but I'm not getting the pushback from the back end of the piston ram. I can't even push it in and out like he does. It does slide about 2/3mm but there is no pressure on it to push it all the way out.
Am I looking at a brake cylinder rebuild/replacement here?
Thanks.
Old Apr 27, 2026 | 08:12 AM
Suede Blue Man's Avatar
Suede Blue Man
Burnt out brakelight bulb of course would trigger this I think, so also start from the bulbs in the rear and trace the lines for rub till they make their connections
Old Apr 27, 2026 | 06:11 PM
John CC's Avatar
John CC
There's a spring inside that should push it all the way out to the stop. Sounds like it's sticking inside. Could be that if you take the seal out and clean the shaft of the piston it will fix it, but at that point you might as well install a rebuild kit for good measure.
There should be be red rubber grease in there to keep things lubed, sealed and corrosion free.
Old Apr 28, 2026 | 05:01 PM
snoozy's Avatar
snoozy
It's increasingly looking like you're spot on. If anyone has any info on rebuilding the brake cylinder, it would be greatly appreciated.
Old Apr 28, 2026 | 05:47 PM
snoozy's Avatar
snoozy
Can anyone confirm if this is the ABS junction box? Pretty sure it is. If so, then I can't bleed the brakes myself for the cylinder rebuild.
Old Apr 28, 2026 | 06:42 PM
hattitude's Avatar
hattitude
That is the junction box between the master cylinder, front caliper lines, and ABS lines.
Why can't you bleed the brakes after your master cylinder rebuild...?
While using the Dealer's Digital Tech 2, or one of the other aftermarket tools for activating the ABS module is always nice to do, as long as you don't "activate" the ABS module until after you get your front master cylinder, brake lines, & calipers bled, no air will get into the ABS module requiring it to be purged.
You can also bench bleed the master cylinder, before attaching it to the main front brake line, to reduce the amount of air you will need to bleed out through the front calipers.
Old Apr 30, 2026 | 12:22 PM
98hotrodfatboy's Avatar
98hotrodfatboy
If you push out on your brake lever does the brake like go out??
I had the exact symptoms and the only fix I could do to remedy it was to super glue a 1/4" copper flare onto the switch and it solved all my problems.. If you zoom in on the pic with the lever in it you can see the flare a little better.. The second Pic is the actual flare that I used..
Old May 3, 2026 | 10:21 PM
snoozy's Avatar
snoozy
Update:
New sensor arrived and installed. Error gone, issue resolved.
When the brake cylinder kit arrives, I'll deal with that issue next.
Thanks
Arf
Aug 28, 2022 06:24 PM
Brydog1
Welcome Area Only
25
Jul 9, 2019 08:18 AM
94fatboy
Dec 3, 2009 11:49 AM
