Does anyone have a Trouble Free Dyna?
Old Dec 31, 2007 | 07:16 AM
  #101
Shrug's Avatar
Shrug
Default RE: Does anyone have a Trouble Free Dyna?
20,000 trouble-free miles here. Had my bars replaced under the recall, but got cool new Wild-1 drags in place of the mini apes installed at MoCo's expense.
I'd better go knock on wood...
Old Dec 31, 2007 | 11:25 AM
  #102
impala's Avatar
impala
ORIGINAL: dyna07custom
Check motor mount bolts not so much replaceing as they just come loose What setting do you have rear shocks on crank all the way with passenger
What do you set the rear shocks at when riding 2 up about 400 lbs?
and do you change this and the rear tire air every time you change 1 v/s 2 up?
Old Dec 31, 2007 | 01:31 PM
  #103
WildBill76's Avatar
WildBill76
Trouble free so far. There is a certain way to torque the motor mounts. Make sure your dealer has the proper procedure sheet for 2006 and later Dynas. Frames and mounts were improved in 2006. But if they are not retorqued properly at the 1000 mile check-up, they can fail due to preloading.
Old Dec 31, 2007 | 02:28 PM
  #104
mbracey's Avatar
mbracey
26,000 miles on my 06 LR, only problem was a bearing in the trans that was replaced under warranty at 9000 miles. Great bike, I love riding it and look forward to putting many more miles on it......
Old Dec 31, 2007 | 03:11 PM
  #105
ShoreRider's Avatar
ShoreRider
9700 miles on mine and not one problem. So now I am certain something will happen...
Old Dec 31, 2007 | 04:10 PM
  #106
boogiewithtuck's Avatar
boogiewithtuck
2006 FXDBI - 20,000 trouble-free miles...
Old Dec 31, 2007 | 06:45 PM
  #107
synisterglide's Avatar
synisterglide
I got a '98 FXD with 27K miles on it. Had to replace the speed sensor TWICE...otherwise, not a bit of trouble with her. No runs, no drips, no errors!
Old Jan 2, 2008 | 02:11 AM
  #108
chaelotte's Avatar
chaelotte
2007 sb 15k no probleme whit exept:
for a wrong fob and alarm on for a full night
wobble on front
1 flat tire
bolt under seat for gas tank go off put e z fix
afther the upper one to
rear master cylinder put litle presure on the break pad when i not using it
so rear break got on fired
good thing i have a total of 7 year of waranty and tow truck near home
but its start well every time i put the key on
even at -26 c
but consider is an H-D so trouble free mean what for you...
will you fly an aiplane made by H-D ...
triumph900
Jul 27, 2015 08:12 AM
Candubrain
Oil Archive (no new posts)
Jun 21, 2014 03:09 PM
Plaidfinger
Exhaust System Topics
Sep 7, 2011 08:52 AM
JohnCT
EVO
Apr 21, 2009 04:40 PM
clayshooterwv
Jul 6, 2006 04:34 PM
