Flat liscense plate ?
Old Sep 23, 2007 | 05:03 PM
Bluedog20's Avatar
Bluedog20
Default Flat liscense plate ?
I really like the look of the liscense plate laying flat on the Fender. I see it in alot of posts. Is that custom, or is there a bracket that mounts flat to the Fender.
Thanks
06 Street Bob
Old Sep 23, 2007 | 05:29 PM
up in minot's Avatar
up in minot
Default RE: Flat liscense plate ?
You can spend the money for the custom kit, or you can find or bend a m/c plate frame to the shape of your fender. Once you buy/make the frame, you can attach it to your factory plate holes, or you can use some thin, outdoor, double sided tape and secure it that way. One of my buddies lilke the look you're going for. He bought the plate frame (shaped like the fender), and used the double stick tape method. It looks sweet, and has stayed on there, with no problems, for about 2,000 miles.
I liked the look of the side mounted plate, so I made a little home jobby for that. If you're interested in that, take a look at this forum;
https://www.hdforums.com/m_2170668/tm.htm
Take Care,
Olkie
Old Sep 23, 2007 | 06:05 PM
labfreak's Avatar
labfreak
ORIGINAL: Bluedog20
Thanks
06 Street Bob
I just got a kuryaken lay back with a molded bendto it that matches the fender. $70.00
Old Sep 23, 2007 | 06:06 PM
07bobber's Avatar
07bobber
[sm=ttiwwp.gif]
Old Sep 23, 2007 | 06:42 PM
SFD_207's Avatar
SFD_207
Got mine frm DRAG Specialties... It uses the original plate mounting holes.
[IMG]local://upfiles/31122/D7B18CAFCEF5461E84B3AC2E00C22996.jpg[/IMG]
[IMG]local://upfiles/31122/1C0DB6E86A16495D86C87C98CFF964DD.jpg[/IMG]
Old Sep 23, 2007 | 07:11 PM
up in minot
The pictures for the side mount are in the link to the forum I put up there...
Where did you get that tail light lense?
Old Sep 23, 2007 | 07:52 PM
SFD_207's Avatar
SFD_207
The taillight is from Kuryakyn. Its the lo-profile LED. Also a "plug-n-play" item...
Old Sep 23, 2007 | 08:41 PM
up in minot
Is it the Laydown Panacea Taillight - Smoke part 4833??
Old Sep 23, 2007 | 08:54 PM
SFD_207's Avatar
SFD_207
It's the Low Profile LED Taillight kit Smoked. pn-/4959 //$119.99
Old Sep 23, 2007 | 11:12 PM
cpa55's Avatar
cpa55
Just ordered one from Motherwell for $20.
