dynojet research
Old Oct 1, 2007 | 06:00 PM
Chipstah's Avatar
Chipstah
Default RE: dynojet research
hk_shooter: Was that your max torque reading or the torque at your max hp rpm reading? - check printout and see if you got a higher torque at a much lower rpm, you likely did much better torque-wise down under 3000 rpm.
Chip
Old Oct 1, 2007 | 06:03 PM
Trotter's Avatar
Trotter
ORIGINAL: SPECIAL ED
I'm holding the print out in my hand right now reading 80.6 HP at 5420 RPMs and 92 Ft lbs at 3837 rpms.The dyno tech couldn't believe it either he kept asking what cam I had in it.I've tried to scan this print out before but it comes out un readable, it's too light maybe I'll try it again today.
Thunderheader's ....... Work....
Old Oct 1, 2007 | 06:07 PM
Trotter's Avatar
Trotter
Can ya shoot me a copy of the print out ?maybe the Rush these motors like some good back pressure..
Old Oct 1, 2007 | 06:10 PM
Trotter's Avatar
Trotter
The Thunderheader's make some great numbers..
Old Oct 1, 2007 | 07:58 PM
hk_shooter's Avatar
hk_shooter
On the print out it's referred to as the "Max Torque" chipster. The torquecurve(more like a flat)started outlike 64ft/lbs@ 2000 RPM's up to the max(72.9) at about 4500 RPM's. Horsepower range was much steeper graph.
I'll see if I can find a scanner, Trotter.
Old Oct 1, 2007 | 08:16 PM
Trotter's Avatar
Trotter
Chip yer numbers are excellent, the torque in the crusing range is great.. He did a good job on thebike.
Old Oct 2, 2007 | 05:25 PM
Trotter's Avatar
Trotter
Looks like the 06 stage 1 download..If you payed to have the bike tuned you need to pay them a return visit.
[IMG]local://upfiles/24219/09B1B8D770874519A1B8C1A73F7D1CA0.gif[/IMG]
Old Oct 2, 2007 | 06:02 PM
Chipstah's Avatar
Chipstah
ORIGINAL: Trotter
Chip yer numbers are excellent, the torque in the crusing range is great.. He did a good job on the bike.
Thanks Skip - Yeah, I was quite pleased and surprised, especially since it was on a Dyno-Mite (?) newly installed a couple of months ago at the dealer (their first dyno tune machine and, I guess, not the most elaborate of the dyno models) - and I had requested their head engine guru do it and he worked his magic for quite a few hours. But, as I've said before, being the cheap SOB I am, their regular charge for a tune is $150 flat which I thought was pretty good, but they were offering a "Back To School" service special for 10% off. So I jumped at it, yet wasn't quite sure what to expect for $135. I guess you sometimes get more than you pay for!! LOL! Just wished they had remembered to install my BCT Monster baffles first which were forgotten on top of a cabinet. Oh well, I ain't complaining.
Chip
Old Oct 3, 2007 | 12:45 PM
hk_shooter's Avatar
hk_shooter
I most certainly am. Thanks Trotter.
08fxstb
May 18, 2008 09:16 PM
hoosierhog88
Dec 8, 2007 02:36 PM
FLSTCI nut
Jun 30, 2006 12:53 AM
twohats
Feb 13, 2006 06:04 PM
Mountainkowboy
Jan 25, 2006 02:40 AM
