2" Tank Lift - Does It Reduce Usable Fuel?
Old Sep 27, 2007 | 09:25 PM
shoptroll's Avatar
shoptroll
Default RE: 2" Tank Lift - Does It Reduce Usable Fuel?
If you look at the fuel pump in the service manual there is a thing on the bottom called a fuel sock. This is a pick-up that runs the length of the tank bottom. My concern is fuel not getting through the crossover when it's low, due to the elevated position. What we need is someone curious enough to run their bike empty while ending up close to a gas station.
Old Sep 27, 2007 | 09:32 PM
jackyl's Avatar
jackyl
ORIGINAL: shoptroll
you use every drop of gas in the tank. i ran out of gas one day after work, being lazy, well that wont happen again, trust me. well since i ran out, i decided to check if there was any gas left. so i used my flash light and looked inmy tank, no gas. so my answer is you use every drop of gas with the 2 inch lift, but it does effect your gauage a little. i havnt check the 3 inch with the gas usage, since i dont feel like running out of gas again, it might be awhile before i check that out. jackyl
Old Sep 27, 2007 | 11:28 PM
Protrucker's Avatar
Protrucker
The farthest that I've gone before refueling was 212 miles, and that was with a 2" tank lift. There was more than a pint of gas left. It onlytook 4.534 gallons to fill it back up.
That wasn't one of my better mpg tanks either. I only got 46.78 mpg & I frequently get over 50 mpg with my best at an unbelievable 58.27 mpg. (this is not BS. I have documented every gallon that has run thru my bike) The best mileages are when riding gently with my wife. (on her own bike)
Old Sep 30, 2007 | 04:06 PM
Nevar's Avatar
Nevar
I have the Cross style LED fuel guage and Jackyls 2" lift. I ran it a few more miles well after the red light came on.
The tank took just 3 gallons to fill it.
Old Sep 30, 2007 | 06:04 PM
sintax's Avatar
sintax
I have a 2" lift along with the digital LED skull fuel gauge. When I hit around 120 miles or so (this is city riding I'm talking about) the last light on my gauge turns red. There is one stage left on the gauge where the red light starts flashing but I generally fill up around the 130 - 140 mark.
I fit a little over 3 gallons of gas in the tank so I must have a ton of fuel in there and am filling up prematurely... but it is kind of one of those things that I really don't want to find out by mistake. I wonder if I could make it closer to 200 miles on a tank...
Old Sep 30, 2007 | 10:24 PM
lilrooster76's Avatar
lilrooster76
Hey rdondes..did you do anything to the handlebars or anything in order to use the lift kit? I also have an 07 SuperGlide Custom and it doesnt seem like the lift would fit with the stock bars and the signals in the stock location
Old Oct 7, 2007 | 10:14 AM
rdondes's Avatar
rdondes
The 2" lift kit will work fine with the stock handlebars. With the handlebars at full, left lock, there will be about 1/2 inch clearance between left turn signal and the tank. Plenty of room. At full right lock, the cables will barely touch the top of the gas cap. So far no problems with a 2" tank lift on my 2007 Super Glide Custom. My gas gauge seems off though - when the low fuel light comes on, the tank will only take at most 3 gallons, so there's at least 1-2 gallons left. The lift looks good and makes cleaning the top of the cylinder heads a breeze.
Richard
Old Oct 7, 2007 | 10:40 AM
ltlo7's Avatar
ltlo7
My gauge was off too after installing the 2" lift so I adjusted the float inside the fuel tank and now thelow fuel light thingy kicks in at about 1 gallon or little bit less.
Old Oct 17, 2007 | 10:31 AM
stingray's Avatar
stingray
ORIGINAL: ltlo7
How did you adjust the float? Is it hard to get to, can you share some more info?
Old Oct 17, 2007 | 04:42 PM
Mr E's Avatar
Mr E
I Bought an led fule gage from the stealer. What junk, 2 years and all of lights have now stopped working. I ride strictly by the odometer. How are the aftermarket LED fuel gages?
rtbuck89
Aug 9, 2014 05:41 AM
lesplay
Apr 15, 2014 04:23 PM
pheur
Jun 15, 2011 02:12 PM
livindadream
Mar 1, 2011 07:44 PM
alb84z31t
Sep 5, 2009 04:48 PM
