screaming eagle 2 pipes
Old Oct 5, 2007 | 01:03 PM
scooterak's Avatar
scooterak
Stage III
Default screaming eagle 2 pipes
I've got a 2005 superglide custom with screaming eagle 2 pipes on it. I wanted it a little louder and was told I could drill holes in the baffles. Has anyone done this and does it have any down sides?
Old Oct 5, 2007 | 01:12 PM
Shrug's Avatar
Shrug
Default RE: screaming eagle 2 pipes
Big City Thunder Baffles. You'll love the sound and perormance and you won't trash your SE-IIs.
Old Oct 5, 2007 | 02:46 PM
JRK5892's Avatar
JRK5892
look into the end of you pipe you should see a cup like lip on the end of the baffel... stick a long bar in there and bend that saucer like cup out... it will be louder... not crazy oooh my god that is so loud but louder none the less
Old Oct 5, 2007 | 03:15 PM
JUSTRIDIN's Avatar
JUSTRIDIN
I took the baffles out & drilled 2 1/2 inch holes in each one. I drilled them in the flat part of the baffle. Sounds great.
Old Oct 5, 2007 | 03:19 PM
remipmc's Avatar
remipmc
i tossed my SE pipes for some vance & hines, and never looked back. hella loud, and the performance increase was amazing. i never got it dyno'd but i can say i definitely feel the difference.
Old Oct 5, 2007 | 03:26 PM
sintax's Avatar
sintax
If you actually have the SE II pipes, and not just the SE's, I highly recommend the Big City Thunder Baffles.
Old Oct 5, 2007 | 04:21 PM
scooterak's Avatar
scooterak
Stage III
ooops, they aren't SE II's just SE. Will Big City Thunder baffles still work?
Old Oct 5, 2007 | 04:24 PM
scooterak's Avatar
scooterak
Stage III
Yeah I guess they aren't SE II just SE. Do you know if BCT makes a baffle for that?
Old Oct 5, 2007 | 05:47 PM
Shrug's Avatar
Shrug
If the SE baffles are removeable, BCT can help. You won't believe the difference.
Strick
Mar 12, 2009 08:29 PM
freebyrd
Jan 9, 2009 07:52 PM
dennis_dicks
Jul 29, 2008 05:42 PM
giovex
May 22, 2008 02:23 PM
BikerDC
Exhaust System Topics
Nov 30, 2005 11:37 PM
