Trouble with handlebars...Help
Old Oct 5, 2007 | 06:11 PM
Blade68's Avatar
Blade68
Default Trouble with handlebars...Help
Out of nowhere my handle bars have become loose. The bars themselves are not loose at the lower handlebar clamp. The whole apparatus is moving back and forth through the upper fork bracket. Everything seems tight. I have no idea what is going on. Anyone know what would cause this or how to fix?
I appreciate any thoughts you might have,
Thanks,
Blade
Old Oct 5, 2007 | 06:48 PM
js1268's Avatar
js1268
Default RE: Trouble with handlebars...Help
well, either your 2 riser bolts that attach your riser to the upper triple clamp have come loose, or your rubber bushings that they go through are just fatigued.... in which case, you either need to tighten the bolts (if they've come loose) ...or you need to replace the rubber bushings with new ones....or better yet, polyurethane ones.
Old Oct 5, 2007 | 06:52 PM
lolife's Avatar
lolife
what he said.....................Polyurethane for sure..................LO.......................
Old Oct 5, 2007 | 11:10 PM
wideglidebob's Avatar
wideglidebob
man get prof help, don!t \screw with something that danferous
Old Oct 5, 2007 | 11:34 PM
Lonestar Superglide's Avatar
Lonestar Superglide
Well it sounds just like what the other guys said. Check the tightness of your bolts and if they are tight and you still have movement your bushings could be worn. Sounds more complicated than it realy is. Its not hard to repair.
Old Oct 5, 2007 | 11:35 PM
anubisss's Avatar
anubisss
Get get polyurethane riser bushings. I think they were about $30 at the stealer...
Old Oct 7, 2007 | 07:06 AM
Blade68's Avatar
Blade68
Thanks for the info, I am going to get some PU bushings and take a look at er...
Blade
Greatscott
Nov 10, 2014 02:41 PM
Mulehide
Feb 24, 2013 07:55 PM
CurtO
May 28, 2008 10:04 PM
Momentor
Sep 10, 2007 07:25 PM
85RoadsterXLS
Feb 17, 2007 11:34 AM
