Ape Question
Old Oct 9, 2007 | 05:43 AM
wfdmedic8's Avatar
wfdmedic8
Default Ape Question
I have been noticing that my bars seem to be drifting back when I ride from time to time. I am constantly checking the riser bolts for tightness, and they don't seem to be loose. Anyone else having this problem???? Anyone have any suggestions fixing this problem, other then riding with the hex key in my pocket to check the bolts and readjust as needed?
Old Oct 9, 2007 | 06:16 AM
Atomic Injector's Avatar
Atomic Injector
Default RE: Ape Question
I have the same issue, my bars or risers are'nt knurled though. I've tried rubber in between the two but it's not working. This week I'm going to try skate board grip tape and see how that works.
Old Oct 9, 2007 | 06:36 AM
GlassBikerNC's Avatar
GlassBikerNC
Take some 800 grit sand paper and cut a strip that is about 1" to 1.5" wide by 4" to 5" long. Fold it in half the long way so it is about 1/2" to 3/4" wide. Put these around the bars where they go into the risers. This helps a lot.
Old Oct 9, 2007 | 09:24 AM
jackyl's Avatar
jackyl
ORIGINAL: Sway_NC_WG
took the words out of my mouth. i did the same thing and works great.
Prodriverdon
Jul 16, 2012 11:50 PM
DocJ
Aug 13, 2010 07:10 PM
darksidebones
Sep 24, 2009 07:43 PM
niteowl02
Sep 7, 2008 10:24 PM
CurtO
May 28, 2008 10:04 PM
