IT JUST QUIT
Old Oct 9, 2007 | 04:28 PM
fixitbychick's Avatar
fixitbychick
Stage II
Default IT JUST QUIT
Motor just quit, like the kill switch was hit. Tried to restart, it tried turning over but with loud ticking comming from lower underneith motor. Checked pushrods still ok, is this possible bent valve or what?[&o] its a 1995 dyna evo with 23k
Its not the starter, and power from battery is good. The ticking is comming from inside the engine. It cranks over but wont start.
Old Oct 9, 2007 | 04:43 PM
labfreak's Avatar
labfreak
Default RE: IT JUST QUIT
Have to say it...check your battery cables and battery...Just in case, easy and rules that out as apossibility.
Old Oct 9, 2007 | 04:45 PM
GrayRider's Avatar
GrayRider
Yep..sounds like a battery issue. Either discharged or cables/connections corroded.
Old Oct 9, 2007 | 05:17 PM
JRK5892's Avatar
JRK5892
I would agree... i know it sounds basic but have you checked the fuses... If it is clicking that could mean you are getting it power and not enough... kind of like a dead battery on a car
Old Oct 9, 2007 | 05:18 PM
JRK5892's Avatar
JRK5892
lower under the motor... check the started... see if that is where the ticking is coming from!
Old Oct 9, 2007 | 09:36 PM
lolife's Avatar
lolife
ignition?...........are you getting fire?..........Fuel?.......... ......... .........LOLIFE.........
Old Oct 10, 2007 | 12:48 PM
zimmy00's Avatar
zimmy00
Stage IV
had the same issue with my bike. It was battery
Old Oct 10, 2007 | 03:30 PM
lone rider's Avatar
lone rider
fuses!
Old Oct 10, 2007 | 06:05 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
charge the battery with a low rate charge (1.25-2.0 amp hr). see if the bike starts then perform a charge system diagnostic test.it's possible your stator checked out and didn't let you know. how old is the battery? is it an electrolyte/acid battery and what is the water level?( use distilled water). but like already mentioned and easiest are the ignition fuses to check. good luck.
Old Oct 10, 2007 | 10:04 PM
AndyV2000's Avatar
AndyV2000
I always told my bike if it gave me any problems I'd trade it in for a Honda; damn thing has never missed a beat in 98,000 miles *lol*
RonS0921
Oct 5, 2022 01:48 PM
Heather Hradek
Aug 27, 2015 04:55 PM
nationalpastime
Nov 23, 2011 07:41 AM
Good Time Gang
Sep 24, 2010 08:44 AM
bandit2
Aug 24, 2008 11:18 PM
