Embarrassing tire question...
Old Oct 14, 2007 | 02:43 PM
Topspin's Avatar
Topspin
Default Embarrassing tire question...
Is there a trick to checking the air pressure in my 1 week old FXDWG? I keep getting "0 psi" readings like the valve stem is too long for the gauge.
Geez... I can't even chew gm and check the air pressure... what gives?
Old Oct 14, 2007 | 02:53 PM
Uncle Scrooge's Avatar
Uncle Scrooge
Default RE: Embarrassing tire question...
This is a new one! There's no trick that I am aware of. Can you try a different gauge?
Old Oct 14, 2007 | 02:55 PM
harleyxlc's Avatar
harleyxlc
Well.....I do have one valve right now that doesn't work with my one gauge, have to use another gauge....so that could be it. Also, I have had a valve cap issue (who would have guessed?). The H-D caps have a little rubber ring inside and if you tighten them down that ring can wedge in the valve. Won't leak, but won't let you check the pressure or add air either.
And good job having the juevos to post a question about how to check your air pressure
Old Oct 14, 2007 | 03:08 PM
Topspin's Avatar
Topspin
tried a digital gauge and a pen gauge... both don't work... gonna check now to see if the o rings are wedged. I got rid of my black caps in favor of some chrome harleys. That could be the prob!
Old Oct 14, 2007 | 03:15 PM
Topspin's Avatar
Topspin
Harleyxlc... THAT WAS IT!!! It was the O Rings wedged inside the valve perfectly. (Something one couldnt do if they tried)
Cmon... I don't feel that stupid now... after all, who woulda thunk it?
Thanks for the help!
Old Oct 14, 2007 | 03:18 PM
harleyxlc's Avatar
harleyxlc
You're welcome! I just took the damn things out after it happened to me.
Old Oct 14, 2007 | 03:27 PM
DougsDyna's Avatar
DougsDyna
ORIGINAL: Topspin
Sure glad you posted your question................ I have been checking the air in tires of all sorts forclose to50 years, and have never come across that one!!!!!!!! Could be a big problem trying to fill a tire on a trip at night in a not so bright location.
Who woulda thunk is right!
DougJ
Old Oct 14, 2007 | 05:13 PM
RonnR's Avatar
RonnR
Same here ,, took a while to figure it out... Even with that ring removed still haveone gauge that works and one that just doesnt get a reading??
Old Oct 14, 2007 | 08:36 PM
hk_shooter's Avatar
hk_shooter
Just goes to show ya, just when you think you've seen/ done it all there's something new to learn every day.
Kuddos on(having the cajones to)ask the tire pressure question, though. I probably would of called the Stealer
Old Oct 14, 2007 | 10:30 PM
sargek's Avatar
sargek
Don't feel stupid topspin, we've all been there. Felt that way the first time (only time) I dropped a socket in my primary when doing a chain adjustment. Don't do that, by the way Unless you have long fingers like I do.
steelerdude1
Jul 12, 2019 04:26 PM
rollingthunder
Jul 19, 2014 07:48 PM
mmcbeat
Wheels/Tires
Jun 17, 2014 10:59 AM
Redlegvzv
Jun 8, 2014 07:09 PM
Rollon
Jun 11, 2009 01:15 AM
