Problems with 96" motor
Old Oct 19, 2007 | 09:40 PM
hondo96inch's Avatar
hondo96inch
Default RE: Problems with 96" motor
ORIGINAL: Hounds2
i have a 2007 fxd with 12500 miles..i had a transmission seal go out...my guess is that it is because the belt was too tight..had the dealer adjust the belt at 10000 and he did 3/8 while on the stand...when the belt got hot it was as tight as a banjo string...after the new seal i had him adjust on the loose side and i think it will be ok..i have asked a couple wrenches if the belt tightens when hot and they say no...i have the only one that does i guess..i think the 96 is a great motor..
scott
My 08 dyna belt gets tighter after a summer temperature run. I atribute it to rear sprocket being aluminum.
Old Oct 19, 2007 | 10:43 PM
Cloud09King's Avatar
Cloud09King
Man!!!...how the heck you got over 12K miles on an '07? What did you do...ride round-trip 'cross country a few times already?
Old Oct 20, 2007 | 05:01 AM
lilrooster76's Avatar
lilrooster76
8k on my 07 and no problems yet
Old Oct 20, 2007 | 05:54 AM
encorebilly's Avatar
encorebilly
ORIGINAL: FXDC Rider
Bought a 07 1200 sportster in Jan 07,put 9000mi on it and traded for an 07 Low Rider with 2800 on it in April 07,it now has 10000 mi on it.Thats 15000 this year with temps not warming up very early here in IND.Took a loss on the trade but love the LR.
By the way have not been over 200 mile away from the home twenty.
Old Oct 20, 2007 | 07:52 AM
Psycho's Avatar
Psycho
Right at 10 k on my 07' since May. So far so good.
Old Oct 20, 2007 | 11:45 AM
JimmysFXDC's Avatar
JimmysFXDC
12.5k on mine no problems yet.
Old Oct 20, 2007 | 01:21 PM
Psycho's Avatar
Psycho
I guess we'll find out soon, as I am now collecting parts to do heads, cams, and 103" build this winter, and plan to romp on it quite regularly.
If the bearings break, I'll fix them. Such is life.
Old Oct 30, 2007 | 12:08 AM
WildBill76's Avatar
WildBill76
I think you need a new indy. Unless someone really buries their tach into the red zone the bottom end should stay happy, as long as the engine is ran with Motorcycle spec synthetic oil. ( The bigger the engine, the hotter it will run.) Synthetics can take the load and heat.
Old Oct 30, 2007 | 12:58 AM
shoptroll's Avatar
shoptroll
Some of the06 dynas and a few early 07's had a problem with the inner primary bearing going out.
Old Oct 30, 2007 | 10:44 AM
mywideglide's Avatar
mywideglide
I heard that a guy saw Elvis alive in a Mall.........
cubcake1
Oct 28, 2007 08:52 PM
HDone
Sep 24, 2006 06:01 PM
wnogood
Sep 12, 2006 04:37 PM
drod
Aug 29, 2006 10:55 PM
bobby_covas
May 17, 2006 09:24 PM
