Rattleing
Old Oct 18, 2007 | 09:13 AM
boa74's Avatar
boa74
Default Rattleing
I have a 2006 Dyna with Samson Big Gun’s 3’s on it for the past 9 month they sounded fine 2 weeks ago I started hearing a tinny rattling sound sounds like it is coming form the front of the bike I have removed the pipes and I see not broken welds on the heat shields. These pipes are all one piece baffles are not removable but when I put pressure on the side of the pipe with my boot it seems to go away. anyone have any ideas The only thing I did around the same time I started hearing the noise was swap out the nuts that hold the pipes to the bracket that is attached to the transmission it came with nylock nuts and I replaced with External Lock Washer K-Lock Nut’s. What is the purpose of the nylock nuts could that be the cause of this noise? I am planning on replacing the lock nuts with nylock nuts this weekend.
Old Oct 18, 2007 | 11:53 AM
paulyv's Avatar
paulyv
6th Gear
Default RE: Rattleing
Your pipes are loose. You may need new clamps to retighten them.
Paulyv
Old Oct 18, 2007 | 12:01 PM
boa74's Avatar
boa74
What clamps do it need
Old Oct 30, 2007 | 02:15 PM
vmons's Avatar
vmons
Stage III
I had the same rattle, it ended up being my keys hitting the frame.
Old Oct 30, 2007 | 06:24 PM
DougsDyna's Avatar
DougsDyna
Check everything attached to your bike......... I have found that every single thing that is bolted to the bike can sound like a engine noise when loose.
It does sound like your pipes ar the problem, though.
DougJ
Old Oct 30, 2007 | 07:02 PM
DGlide04's Avatar
DGlide04
Nylocks make it harder for the nut to back off the bolt and loosen up.
Old Oct 30, 2007 | 09:14 PM
JayFromPa's Avatar
JayFromPa
I had a loose hose clamp on my heat shield that made this same sound when I got on it a little.
Like Doug said though, there is so much chit that can come loose it all sounds like engine noise at some point.
Old Oct 30, 2007 | 11:06 PM
darkdyna06's Avatar
darkdyna06
My Python 2-1 just started doing the same thing. I tightened up all the heat sheild clamps, and it went away then came back again. Pain in the a$$.
When funds allow, Im going to a black thunderheader with no heat sheilds, that should fix it.
Fatbob usmc EOD
Dec 17, 2012 08:33 PM
APEDnLOW
Jul 7, 2012 08:05 PM
RHillbilly
Nov 21, 2008 07:34 AM
boa74
Apr 14, 2008 11:06 AM
boa74
Exhaust System Topics
Oct 19, 2007 01:52 PM
