Rattleing
Old Oct 18, 2007 | 09:32 AM
boa74's Avatar
boa74
Default Rattleing
I have a 2006 Dyna with Samson Big Gun’s 3’s on it for the past 9 month they sounded fine 2 weeks ago I started hearing a tinny rattling sound sounds like it is coming form the front of the bike I have removed the pipes and I see not broken welds on the heat shields. These pipes are all one piece baffles are not removable but when I put pressure on the side of the pipe with my boot it seems to go away. anyone have any ideas The only thing I did around the same time I started hearing the noise was swap out the nuts that hold the pipes to the bracket that is attached to the transmission it came with nylock nuts and I replaced with External Lock Washer K-Lock Nut’s. What is the purpose of the nylock nuts could that be the cause of this noise? I am planning on replacing the lock nuts with nylock nuts this weekend.
Old Oct 19, 2007 | 01:43 PM
Doc 1's Avatar
Doc 1
Default RE: Rattleing
If you put pressure on it and the sound goes away, I'd say it is a heat shield or loose baffle.
Old Oct 19, 2007 | 01:52 PM
dawg's Avatar
dawg
Had a loose baffle once that rattled and drove me nuts.
Big Dave
Dec 29, 2016 09:05 AM
Fatbob usmc EOD
Dec 17, 2012 08:33 PM
RHillbilly
Nov 21, 2008 07:34 AM
boa74
Apr 14, 2008 11:06 AM
boa74
Oct 30, 2007 11:06 PM
