HD Performance Spark Plugs
Old Oct 23, 2007 | 06:18 PM
2002fxdp's Avatar
2002fxdp
Default RE: HD Performance Spark Plugs
all platinum plugs are pregapped and not to be adjusted. of course check to make sure they wernt dropped and the gap is .010 but other than that dont mess with em. anyone try the iridium plugs?
15 to 20 bucks a pop but you only need 2
Old Oct 23, 2007 | 06:34 PM
DougsDyna's Avatar
DougsDyna
ORIGINAL: 2002fxdp
I put a set in, but I believe I only paid about $8 a piece for them. Don't remember why I tookthem out, exactly.
I think I was having a conflict with the check engine light coming on with them in.
DougJ
Old Sep 9, 2014 | 11:59 AM
Rascally's Avatar
Rascally
2nd Gear
This statement is not correct... or at least it mis-leading.
"all platinum plugs are pregapped and not to be adjusted"
Plugs do come pre-gapped, but the same plugs can be used for many engines, and the required gap is not the same. Today I called NGK to ask why their Iridium plugs come with instructions that clearly say, "Do not gap these plugs". Their answer was, we've had customers that change the gap by putting pressure on the centre electrode, and these new electrodes crack or break with such pressure. The tip cracks off... gets damaged... doesn't work properly.
So, to prevent damage by those who do not know how to gap a plug correctly, NGK puts that message on their packaging.
This was the answer from both NGK USA and NGK Canada (I called both). NGK Canada, referred me to a link that describes the correct way to gap a plug. And, with no reservations, NGK Canada Tech Support advised that yes, indeed, all plugs should be gapped to the engine manufacture's specifications.
I have gapped my new NGK Iridium plugs to .40", as per my HD bike's spec.
I suggest that all do their own research, but wanted to share what I've learned today.
http://www.ngkplugpro.ca/content/con...sparkplugs.pdf
Cheers,
Randall
Last edited by Rascally; Sep 9, 2014 at 12:08 PM. Reason: edited to add link to NGK PDF doc
Las Vegas Jim
Engine Mechanical Topics
May 28, 2024 09:20 AM
cajun1957a
Jan 30, 2017 07:52 PM
asahi1234
Jul 26, 2016 03:42 PM
T_Dogg80
Jun 6, 2013 09:53 AM
SportyPig
Dec 3, 2006 12:42 PM
