Is True Stage I worth the $$$?
Now I do not know if a factory re map will keep up with four pipe changes to get the correct sound, air cleaner change. and now a new set of plugs and wires,and yes I will have to re adjust for that.
In thinking about setting up an appointment with my dealer, I believe the SERT was what they referred to for $469.00 HOWEVER, I do specifically recall saying..."so the $469.00 is for the SERT?" And the girl said..."the what?" I said, "the Screamin' Eagle Race Tuner," and she said..."no...we use a different kind of module..." which right there I should have asked to speak with the service manager, but I just remained confused, made the appointment, then hung up went...."wait just a second here...!" In all fairness, maybe there is a brand new tuner out there that we all have not heard of yet. But I tend to doubt it.
So basically after reading everything, taking a look at my manual, talking to a rep from Vance and Hines, as well as a long-time HD tech it seems that the reality is that there is really NO wrong way to do a Stage I so long as you :
1) Change the A/C to a hi-flow type
2) Change your stock pipes with an exhaust that allows more airflow out - slip-ons keep it real simple
3) Adjust the EFI system electronically with a fuel management device made by a "reputable" manufacturer, OR by the dealer for anywhere from 150 to almost a grand depending on what you are looking to gain and do in the future.
H-D's SERT has a lot of good things in it, but really, unless you are radically changing your set-up, or going beyond a simple Stage I now or plan to in the future, how many parameters really need adjusting for just a bit more air flow in and out?
V&H states that their own "FuelPak" was designed and tested with their own exhausts utilizing the HD SE air filters. At a couple hundred bucks one time cost, and a do-it yourself install and set-up so easy a monkey (with really good dexterity) could do it, how can you justify HD doing anything to your bike for their costs and labor rates?
I can't say if this has really dmamged my trust in my local dealer, but it didn't do it any favors either. There is another, smaller dealer a litle farther, but a really nice ride from here...I think they may get my next major purchase.
Thanks again for all the "IMHO's" and the experienced advise.
