will these risers fit?
Old Nov 21, 2007 | 11:57 AM
thecabinboy's Avatar
thecabinboy
Default will these risers fit?
Do you guys think these risers DS290126 http://www.dragspecialties.com/fatbook/15/268/3870509my 2007 FXDBI? Thanks, Jeff
Old Nov 21, 2007 | 12:02 PM
TOMMAY's Avatar
TOMMAY
Default RE: will these risers fit?
I think they will,but if you go over about four inches you may have to replace some cables.
Good Luck
Tom
Old Nov 21, 2007 | 12:18 PM
thecabinboy
I want to get the 2 1/2" ones
Old Nov 21, 2007 | 12:46 PM
hk_shooter's Avatar
hk_shooter
ORIGINAL: thecabinboy
Should be no problem. I put taller ones than 2 1/2"on mine, had to tweak the brake line a bit. That was all. Besides, I think the stock Bob ones are 2 1/2".IIRC.
Old Nov 21, 2007 | 01:00 PM
twofish's Avatar
twofish
http://www.putfile.com/pic.php?img=6846762
My new stock 07 FXDB came with 2" risers.
I had 4" HD straight rises installed with no cable change, no problem.
They did make an adjustment on break line only.
Old Nov 21, 2007 | 01:37 PM
Chipstah's Avatar
Chipstah
Do you guys think these risers DS290126 http://www.dragspecialties.com/fatbook/15/268/3870509 my 2007 FXDBI? Thanks, Jeff
Yes - stock street bob risers are 2", and over 4" you gotta change cables, between 2" and 4" you just gotta bend brake line. Description in your link states that stock clamp will work, ie. they are offset for the riser clamp bolts on a stock clamp. I put 3" risers on my st bob no problem, just bent brake line carefully and reversed brake line clamp on the triple tree.
Old Nov 21, 2007 | 02:35 PM
thecabinboy
ORIGINAL: hk_shooter
ORIGINAL: Chipstah
Ok I ordered Them but I think the stock risers are 1" they are little stubby things
[IMG]local://upfiles/10901/B2636C52897C45FA830CA121EC53ECC9.jpg[/IMG]
[IMG]local://upfiles/10901/ED380A1E93A345EDB12C3FA1F3722E78.jpg[/IMG]
Old Nov 21, 2007 | 02:43 PM
akflyer's Avatar
akflyer
I just put the same 2.5" risers on my '07 Bob. They work great, and the stock cables are fine.
Old Nov 21, 2007 | 02:52 PM
hk_shooter's Avatar
hk_shooter
Could be, cabinboy. Actually I'm not sure where the 'measurement' actually comes in. I would imagine that one end of the meassurement is where it attaches to the tree, but is the other at the bottom of the circle(where the bars go) or a imaginary centerline(where the risers clamp together), or to the top of the circle? I measure mine and I get 5 1/2" to the centerline., and I thought they were 4 inchers.
Old Nov 21, 2007 | 05:59 PM
Chipstah's Avatar
Chipstah
Most, but probably not all, in my experience measure from triple tree to centerline of bars.
Mr.Softy
May 20, 2016 10:18 PM
Barrier
Feb 8, 2015 12:24 PM
c-note
Jan 24, 2015 11:33 PM
lowend73
Jun 29, 2013 05:48 AM
jughed geno
Dec 9, 2012 06:14 PM
