fork gaiters
Old Nov 26, 2007 | 09:56 PM
tree88's Avatar
tree88
Default fork gaiters
How big a pain in the *ss are they to install? thinking about goin the kuyrakin fork covers/ fork brace/ gaiters/ no fender route (cause some dumb broad sat on my front fender while it was parked at the bar and bent it). Either that or does anyone make a chrome fender for a wideglide? any help would be appreciated.
Old Nov 26, 2007 | 09:58 PM
VenturaChop's Avatar
VenturaChop
Default RE: fork gaiters
i got a fender for sale
Old Nov 26, 2007 | 09:59 PM
JRK5892's Avatar
JRK5892
it is easy! if you have the right equipt... i picked my bike up with a mold hoist and then slid the gators on... you just ahve to get the forks off the ground enought to slide them down a bit...
Old Nov 26, 2007 | 10:02 PM
tree88's Avatar
tree88
ORIGINAL: VenturaChop
Will it fit a 21" front wheel?
Old Nov 26, 2007 | 10:14 PM
VenturaChop
i street bob fender should fit since the diameter isnt that much bigger....its a stock harley front fender
Old Nov 26, 2007 | 11:12 PM
JRK5892's Avatar
JRK5892
what color is that front fender?
Old Nov 27, 2007 | 12:11 AM
VenturaChop
black as night
Old Nov 27, 2007 | 08:39 AM
Chipstah's Avatar
Chipstah
ORIGINAL: tree88
No problem at all on install:
more pics in gallery. Go w/o fender if you can stand the road kill! No problems so far.
Old Nov 27, 2007 | 03:36 PM
SPECIAL ED's Avatar
SPECIAL ED
Just a bit time consuming. You will have to get at least the front end off the ground and probably the front wheel off.I suppose you could leave the front wheel on if you had some help.In any case you simply slide the tubes out of the triples drop the gaitors onto them and reassemble.The ones that I have just fit in between the sliders and the top triple clamp so there's no need for cutting or clamping anything.One more thing I forgot to mention you will have to remove the front brake caliper from the slider and secure it some how.I tied mine up to the handlebars with an old rag.
Old Nov 27, 2007 | 03:59 PM
TARTAN2's Avatar
TARTAN2
Anyone tried slicing them down the back and lacing them up ?
Figured I might try this and see what happens .
I know lazy way of doing it but a lot safer if they turn out ok .
