16" Solid Wheels on Dyna ..Look
Old Dec 8, 2007 | 03:37 PM
powdercoater's Avatar
powdercoater
Default RE: 16" Solid Wheels on Dyna ..Look
Good call on getting all that stuff powder coated... but why have the legs painted?? The legs are the parts that take the most abuse from the road and would benefit the most by being powder coated!
Old Dec 8, 2007 | 04:13 PM
abcd9906's Avatar
abcd9906
I was thinking paint because I didnt know if when its baked if it would ruin all the seals and everything else. If I paint it with some Quality Catalyzed epoxy or urethane it should hold up better then bomb can BBQ paint. If your a powder coater gimmie some tips on preparing my lower legs to bring them to my powdercoater.
Old Dec 8, 2007 | 08:31 PM
reh13's Avatar
reh13
>>>(you can also get raked trees if you want)<<<
The stock 07 wide glidetrees are raked 2 degrees.
Old Dec 9, 2007 | 06:59 AM
powdercoater
You are correct about the seals, the legs must be removed from the tubes and all seals removed. That takes about 30 minutes MAX after they've been removed from the bike.
Once a powder coater gets them [legs] they will be thoroughly degreased, reflectors and stickers removed, media blasted, another degrease, pre-treatmentand rinse, pre-baked & cooled, another minor cleaning if necessary, masked then FINALLY powder coated. Well, at least that's OUR process and BTW we put 2-coats of powder on them.
Sure, that's a lot more involved than just shooting liquid paint on them but you'll get a much better end result that you won't have to worry about a year or two down the road. Since powder coat is flexible it won't chip or crack like the much harder liquid paint... THAT'S why it's so much better for durability.
There are a lot of examples on the web site below of powder coated fork legs, and anything else you may be thinking of doing to give you ideas of what's possible.
Old Dec 10, 2007 | 12:00 AM
abcd9906's Avatar
abcd9906
thanks for the info! I checked your website ..; prices are fair .. i might send a few things to ya and see what you can do.
USMAMule
Dyna Parts
May 1, 2018 07:41 AM
USMAMule
Stock Harley Take Offs
Apr 30, 2018 03:57 PM
Xman75
Dec 29, 2011 06:08 AM
screamin 110
Sep 20, 2009 03:10 PM
drhooligan
Aug 22, 2009 08:18 PM
