Torque value a/c studs
Old Dec 13, 2007 | 11:09 AM
mud's Avatar
mud
Default Torque value a/c studs
Has anyone got the torque value handy
for the Screaming Eagle
air cleaner mounting studs - item 6
breather screws C should be 22-24, right??
mud
Old Dec 13, 2007 | 11:15 AM
2007fxdc's Avatar
2007fxdc
Default RE: Torque value a/c studs
Mud, seems I remember the torque values on the Big Sucker kit being very light. Not sure about the SE kit. Big Sucker I think was like 5 - 7 ft. lbs.
Old Dec 13, 2007 | 12:43 PM
mud's Avatar
mud
ORIGINAL: 2007fxdc
Thanks Greg. That would be 60-84 in lbs.
I already had the loctite on,
so I took a guess at 60 in lbs.
If anyone has the number from the HD source,
I'd like to get it from you.
Overtorque here definately can damage the gasket.
mud
Old Dec 13, 2007 | 12:52 PM
Cornhusker's Avatar
Cornhusker
I can tell you on the Ness BS Mud, and I would imagine it would be the same as the SE plate.
36-60 in lbs. 3-5 ft lbs.
Old Dec 13, 2007 | 01:28 PM
glide05's Avatar
glide05
mud -
from kit 29440-99c instructions rev 2006-04-19
breather screws (C) = 120-144 inch lbs
air cleaner studs (6) = 55-60 inch lbs
now in my diagram - the labeling is different, but all of the same parts are shown?
Old Dec 13, 2007 | 01:54 PM
mud's Avatar
mud
ORIGINAL: 07 StreetBob
Thanks Keith. Appreciate it.
That sounds like a good range.
I'd say the higher end myownself.
Does the ness kit call out a value
for the air cleaner to the studs??
#7 in my image from above.
mud
mud's Avatar
mud
ORIGINAL: glide05
mud -
Thanks glide. That's about what I had guessed.
I appreciate all the quick replies.
I'm gonna photoshop these numbers
into the above scanned page
so I don't hafta keep askin.
mud
Old Dec 13, 2007 | 03:39 PM
Cornhusker's Avatar
Cornhusker
36-60 in lbs...3-5 ft lbs. Same as item #6.
I went with the higher end on both.
Keith
ORIGINAL: mudpuddle
mud
Old Dec 13, 2007 | 06:23 PM
mud's Avatar
mud
Thanks again Keith
Keith
ORIGINAL: mudpuddle
mud
Yo_Boss
Engine Mechanical Topics
22
May 20, 2017 09:06 AM
3itodd
Dec 31, 2012 12:10 PM
dontdropit
Nov 17, 2012 11:17 PM
bagman1
Sep 9, 2012 05:38 PM
twhill3
Jul 10, 2009 06:35 PM
