Thanks jmpancoast, I really want to avoid swapping out the tripple trees because I just ran all the wiring inside the bars. Was a bit too tedious. done with that *****! I think if i can find a hub and wheel that works I will go the route you suggested. seems much more cost effective and most of all less work. work smart not hard is the motto i try and stick with. Any ideas what hub would work with the stock setup i have now?
You can either use the hubfrom your stock front wheel, or buy a used laced 19" wheel from an 06 or later Dyna. You can probably find a used wheel on eBay or on the forum for $100 - $150 bucks. Last week a wheel with a bent rim sold for $50.00. Something like that would be idea since you only need the hub anyway.
