Axle size
Old Dec 18, 2007 | 05:37 PM
Dynaflyer's Avatar
Dynaflyer
Default Axle size
Howdy, Have a axle part number for a Wide Glide front wheel but can't seem to get any info Via Google, ebay and theHD dealer as to which size this is. A 3/4" or a 1" ???? part number 40923-06
Thanks Brohams.
Happy Harley Days!!
Old Dec 18, 2007 | 09:38 PM
FastHarley's Avatar
FastHarley
Former Sponsor
Default RE: Axle size
measure it. Takes less time than google
Old Dec 19, 2007 | 02:45 AM
Dynaflyer's Avatar
Dynaflyer
Thanks, Yea that is what I could do if I had it. I only have the part number NOT the Physical part.
Cheers.........
Old Dec 19, 2007 | 03:19 AM
jmpancoast's Avatar
jmpancoast
ORIGINAL: Dynaflyer
Thanks Brohams.
Happy Harley Days!!
I just looked in the 06 parts manual. The 40923-06 is the correct axle number for a 06 Dyna Wide Glide and is a one inch axle.
Old Dec 19, 2007 | 05:21 AM
FastHarley's Avatar
FastHarley
Former Sponsor
ORIGINAL: Dynaflyer
Cheers.........
I am sorry I do not own a 06 to measure mine to be accurate. I wish I could help you out. THe 40923-06 (06 part means it was only made for the 06 amd maybe later models). I have a 05. Sorry
Old Dec 19, 2007 | 11:58 AM
Jay Risk's Avatar
Jay Risk
I'm curious- are the '07 and '08 Dynas also 1" axles? I read the Fat Bob is 25mm, so fitting lower legs on an '06 Street Bob in order to add dual front brakes would require some milling of the lowers. Jay
Old Dec 20, 2007 | 06:17 PM
Dynaflyer's Avatar
Dynaflyer
Thanks Brothers,
Looking into a 21" laced profile wheel mod this winter and have a good deal on a 21" off of a 2005 night train. Looks like that won't work unless I replace the bearings with 1". Thanks for the info on the Axle jmpancoast.
Old Dec 20, 2007 | 06:35 PM
jmpancoast's Avatar
jmpancoast
Not sure if its cost effective, but another way to do it would be to get the train rim laced to you hub.
I have just ordered a 21" rim and spokes to do thison my 06 Super Glide.
Old Dec 21, 2007 | 04:08 AM
Dynaflyer's Avatar
Dynaflyer
jmpancoast, Wow that is a option. heck of a lot More cost effective and much less hassle. Be sure to post some pics when you get er done. Your scoot is already top so that should just finish it off.
Old Dec 21, 2007 | 04:16 AM
jmpancoast's Avatar
jmpancoast
I saw from your profile that you have a 06 FXDL. The train hub won't fit in your current forks. In order to use that wheel, you would have to change bearings and triple trees.
I bought the rim for $100.00, the spokes for $35.00, the tire, tube and rim strip will be about $100.00, and probably around $150.00 for lacing and getting it trued.
