Gas tank question
Old Dec 19, 2007 | 10:28 AM
DynaDogg's Avatar
DynaDogg
Default Gas tank question
Does anybody know if a gas tank for a fuel injected bike will work on a carbed bike?
I've done a search on here and can't seem to find the answer.
thanks
Old Dec 19, 2007 | 10:34 AM
atillman's Avatar
atillman
Default RE: Gas tank question
When I was repairing a tank last summer, I pulled the small 1/2 gallon plastic tank off a leaf mulcher and bungee corded it to the frame and it worked just fine. I think just about anything will work just so long as you.......
wear the proper gloves....
tie the do-rag right....
fill in the small hole in the back of the front fender....
place you HOG sticker on properly....
Old Dec 19, 2007 | 10:40 AM
2007fxdc's Avatar
2007fxdc
ORIGINAL: atillman
So, do tell sir, what is the proper protocol for all of the following? Enquiring minds want to know...
wear the proper gloves.... (fingerless or non-fingerless?)
tie the do-rag right.... (knot or bow?)
fill in the small hole in the back of the front fender.... (with what, a screw?)
place you HOG sticker on properly.... (proper method or location or both?)
Old Dec 19, 2007 | 10:50 AM
grumpy irish again's Avatar
grumpy irish again
I hear that little hole is warrentee detector if pluged you lose
any body know what the heck that hole is really for????
Old Dec 19, 2007 | 11:06 AM
2007fxdc's Avatar
2007fxdc
ORIGINAL: grumpy irish again
Ummm, to put one of these on? Damned if I know...
[IMG]local://upfiles/41150/0F5B77F2FC874FF2A51E03DF32078A7C.jpg[/IMG]
Old Dec 19, 2007 | 11:12 AM
mongoose's Avatar
mongoose
Lightening.
Old Dec 19, 2007 | 12:07 PM
dyna07custom's Avatar
dyna07custom
the holemarks the place to start cutting
Old Dec 19, 2007 | 06:29 PM
DGlide04's Avatar
DGlide04
Sorry I don't know the answer to the hole question but a tank from an EFI bike should work just fine. I have a carb'd 2004 FXD and put a tank from an 2006 EFI bike on this past year as part of a custom sheetmetal swap. the only thing you'll probably have to replace is the small piece that threads into the tank. Carb has a petcock, EFI no petcock assbly. Reuse the one from your carb'd tank and it is a direct swap.
Old Dec 19, 2007 | 06:31 PM
DGlide04's Avatar
DGlide04
I should have added that the HD parts manual at least for my 2004 shows the same part number for both the carb and EFI tanks for an FXD 61590-04.
Old Dec 19, 2007 | 06:48 PM
JayFromPa's Avatar
JayFromPa
Well, back in the old days, bikers would just put a little hair around it and have at itduring lonely nites on the road...............[8D]
