Black headers/exhaust...
Old Dec 29, 2007 | 12:08 PM
boogiewithtuck's Avatar
boogiewithtuck
Default RE: Black headers/exhaust...
ORIGINAL: SPECIAL ED
I know you probably don't want to hear this but for $300 you can paint them yourself about 100 times.High heat paint is allot better than it used to be it's possible to get a really nice finish if you buy quality paint and do the prep work. For around $60 you can wrap and paint it yourself.
I'm with Ed - 12,000 miles on my SEII slips and no touch ups yet (I live on a gravel road). Had my heat shileds powdercoated about 16,000 miles ago; again, no chips or touch ups. Rustolium Hi-Temp is a great product.
Old Dec 29, 2007 | 12:23 PM
powdercoater's Avatar
powdercoater
Boogie has the right combo. High temp paint on the pipes and powder coat the heat shields and mufflers. It sure wouldn't cost $300 and will last.
Old Dec 29, 2007 | 12:31 PM
hk_shooter's Avatar
hk_shooter
Not cheap, but I'm really thinking about the RB Racing LSR 2 into1's.
Old Dec 29, 2007 | 12:40 PM
twofish's Avatar
twofish
I also enjoy my Rinehart's 2 into 1 exhaust.
However I'm on my second end cap. They sent me a new one.
The first one turned a pinkish color after a few thousand miles.
So if you have your exhaust coated or pained
I would have the end cap done also. IMO anyway.
Old Dec 29, 2007 | 12:53 PM
Big Twi$t's Avatar
Big Twi$t
ORIGINAL: boogiewithtuck
After second thought...I might do this. Will the muffler be alright powdercoated w/o being ceramic?
Old Dec 29, 2007 | 01:00 PM
hk_shooter's Avatar
hk_shooter
I had some SEII's done in black wrinkle powder, to match the engine, heat shields,and I got a slight bit of discoloration,(kind of a slightly flatter/grayish color). I then had my Rush's done with hi-temp powder, satin black, and have had no problems. I don't think that 'regular' powder coat will stand the heat, but hi-temp stuff seems to be thte trick.
Old Dec 29, 2007 | 01:54 PM
powdercoater
hk_shooter - The problem you had was due to the textured powder. Use a smooth finish and in most cases it'll be fine. Now, if you have a serious restriction in the muffler that causes a hot spot you MAY see a slight discoloration even with the smooth finish.
brypink - If you've been running those pipes and don't see any "bluing" in the chrome on your muffler, you won't have any problems with powder.
Old Dec 29, 2007 | 02:52 PM
darkside's Avatar
darkside
If you go with Jet-Hot you won't be disappointed with the quality. I had my Thunderheader coated and theprocess is top notch.It also cut down alot of the heat on my leg radiating from the pipe.The only probI have is I ordered the flat black coating and after putting it on ,the gloss would have looked better.They sent me a twenty percent off coupon even afterI explained it was my fault.I'll use them for all me coating needs in the future.
Old Dec 29, 2007 | 03:29 PM
hk_shooter's Avatar
hk_shooter
ORIGINAL: powdercoater
Thanks powdercoater. That's what we, the coater and myself, thought too. Mine was a experiment, sort of. He didn't charge me, and said it may not work out. It definately only dis-colored at areas where the 'hot spot' (baffles/restrictions) are. I never did have any blueing on the SEII's. Would putting one coat over the other work any differently? Such as hi-temp first then wrinkle, or vice-versa? To somehow achieve the black textured look, without the color changes. TIA.
Old Dec 29, 2007 | 03:32 PM
tobyhd1's Avatar
tobyhd1
Take a look at www.faic.cc ,you can get them black.Toby
