07 FXDBI FORWARD CONTROLS ?
Old Jan 1, 2008 | 11:16 AM
kjkustoms's Avatar
kjkustoms
Default 07 FXDBI FORWARD CONTROLS ?
I HAVE PURCHASED A SET OF BIKERS CHOICE FORWARD CONTROLS FOR MY 07 STREET BOB. I HAVE INSTALLED THEM, THEY LOOK AND FIT GREAT, BUT MY QUESTION IS: WHAT TO DO ABOUT THE FORWARD SHIFT ARM? I DONT WANT TO PULL THE INNER AND OUTER PRIMARY TO REMOVE THE SHAFT, ANY SUGGESTIONS?
Old Jan 1, 2008 | 01:38 PM
amish's Avatar
amish
Default RE: 07 FXDBI FORWARD CONTROLS ?
dont know what to hepl u here. i had mine done when i got it the stealer did it. they said you had to take of the primary to do it so i guesss that is what u will have to do.but im guessing there are some guys on here who know how to get around it
Old Jan 1, 2008 | 02:58 PM
WS6 Formula's Avatar
WS6 Formula
Read post #5 https://www.hdforums.com/m_1828627/tm.htm
Old Jan 1, 2008 | 03:06 PM
ShoreRider's Avatar
ShoreRider
Left mine in place and put the chrome spline cover that came with the Kuryakyn kit. I've put 4K on her since putting on the forwards and have yet to have a problem with it binding anything. There really isn't any place on my FXDC to tie wrap it to, probably similar situation you are having to deal with.
Old Jan 1, 2008 | 06:28 PM
oldsporty1's Avatar
oldsporty1
Did the samething that Shorerider did. Have had no problems. If you push the shaft in as hard as you can by hand and then put the cover on it will creat pressure on the shaft and hold it where ever you put it. You can try that.
Old Jan 1, 2008 | 07:22 PM
JayFromPa's Avatar
JayFromPa
I did what WS6 did. Takes a little effort but worth it not to have that ugly nub sticking out of the primary.
Old Jan 1, 2008 | 07:25 PM
boogerbooger's Avatar
boogerbooger
What WS6 did. Worked fine. Might make your arm a little tired, but in my opinion a worthy cause. No cover removal at all. . .
Old Jan 1, 2008 | 09:55 PM
rok312's Avatar
rok312
Got a forward control kit for xmas. Plan on doing what WS6 suggests when I finally get around to installing it. Originally, I was going to tackle the primary removal - thought it might be fun. But then I came to my senses and figured it just wasn't worth the hassle. I was hesitant to go the hacksaw routeuntil I took a close look at the area in questionand saw how much room was back there to play around with and what the job would entail. I literally chuckled out loud when I realized how easy it was going to be.
Anyways, I figure if I ever need to go back to mid-controls for whatever reason, I'm sure I could pick up a spare, unmolested mid-shift shaft from someone on this forum who went the 'official' primary removal route (or God forbid, I could pick up a new one from the dealer).
Old Jan 2, 2008 | 01:53 AM
chaelotte's Avatar
chaelotte
i instal the one form hd i left the shaft in place to see how i like the feeling afther couple ride and the rear disc break on fire i decide to go back on mid
something wrong happen on break pedal still not sure what happen but it wont go back at the good place
but if you like it and want to removed the shaft just take a skillsaw and take all the caution that riquire to opperate that tool and try to put tape near the engine and primary case toprevent scratch it and youll be fine
but not sure if you have to removed the front case if you have to remember thers oil inside the case
so try to pull it afther cuting and if no moving just removed the case and pull out the shaft from the inside and afther re instal the bolt ( 22 or something maybe more) and retorq to specific value
its suposse to be an e z job
i read this about 1 year ago here in hdf
try the searchmenu whit foward for dyna
Isalgue
Sep 16, 2023 10:53 AM
Belson_c
Sep 26, 2017 08:13 PM
Jben103
Apr 12, 2015 03:37 PM
Ybnormal67
Oct 26, 2008 08:54 AM
davidsdad
Jun 9, 2007 10:46 AM
