dyna exhaust
Old Jan 1, 2008 | 12:15 PM
jimt's Avatar
jimt
Default dyna exhaust
Can I make a softail exhaust fit my dyna. I have a chance for a good deal on a set of python pipes but they are off a softail.
Old Jan 1, 2008 | 01:58 PM
nkauf21's Avatar
nkauf21
Default RE: dyna exhaust
I don't think so. The mounts are different. I'm sure with enough fabrication you could make them fit, but thats alot of work when you can get a set made for your bike.
Old Jan 1, 2008 | 02:51 PM
pepesworld's Avatar
pepesworld
I have a softail and a Dyna, main difference, whichI didn't realize at first, is that the softail being hard mounted to the frame, the exhaust including individual mufflers can be bolted to the frame also. the dyna however is rubber mounted so the engine can move around (shakes violently) independant of the frame so...the exhaust and mufflers cannot touch the frame, but must be very securely mounted to the engine so as to withstand the violent shaking. However a softail intended slip on may be able to be used on a Dyna with the dyna clamps as they are entirely supported by the header anyway. But a softail headerwill have totaly different mounting brackets.
tvr
Jan 25, 2020 04:59 PM
blair
Jun 5, 2013 02:14 PM
nathanw
Mar 15, 2009 09:56 PM
bL33d
Feb 18, 2009 06:55 PM
fxstcguy98
Exhaust System Topics
Feb 1, 2006 02:31 PM
