Solid rear wheel on a 2007 WG
Old Jan 5, 2008 | 08:47 PM
Topspin's Avatar
Topspin
Default Solid rear wheel on a 2007 WG
Will a sportster, fatboy or deuce solid rear wheel fit on my WG with no modifications?
I'm dying for a solid wheel but want something that bolts right up.
What should I look for?
Old Jan 5, 2008 | 09:07 PM
nkauf21's Avatar
nkauf21
Default RE: Solid rear wheel on a 2007 WG
The sportster wheel is a 16" and your bike is a 17" so that won't work. I don't know about the others. Just curious, why a solid wheel. I've always thought it looked kind of strange with one solid and one spoked.
Old Jan 5, 2008 | 09:10 PM
Topspin's Avatar
Topspin
ORIGINAL: nkauf21
1. I like the look.
2. I feel safer with a tubeless tire on the rear.
3. Those rear spokes are a **** to get to and clean. It's nearly impossible.
Old Jan 5, 2008 | 09:16 PM
nkauf21's Avatar
nkauf21
I do agree that those back spokes are a pain to clean. I think I have seen some other Wide Glides with 17" Deuce rear wheels. You might want to look into one of those.
Old Jan 5, 2008 | 09:20 PM
drdave's Avatar
drdave
you can put up to a 18x5.5 rear wheel on your bike without any modifications.
i have put a chrome deuce rear wheel on my 02 fxdwg without any changes needed. it simply bolted in place and i used a 170 tire for my fender width. i may have been able to use a 180 but the 05 and before fxdwg have a slightly narrower fender width than the newer models. i have heard some say that you may have to take a dremel and slightly trim the belt guard (or simply remove the belt guard if you like that look) to accommodate larger tires.
to down to the do it yourself section on this forum
look at the chassis, suspension, etc subdivision
go to the "harley rim sizes" titled thread and it will give you the maximum tire and wheel size you can put on your bike without modifying anything. then find a wheel and tire that is solid and that size and as long as the axle fits - you are good to go.
Old Jan 5, 2008 | 09:46 PM
Topspin's Avatar
Topspin
ORIGINAL: drdave
This is the part I'm worried about
Old Jan 6, 2008 | 04:35 AM
jmpancoast's Avatar
jmpancoast
There is a member named Veniculum who has an 06 WG with a chrome, solid rear wheel on a 1" axle. He doesn't post in here as much as he used too, but there are a lot of threads in which he has contributed to about this. Do a search under his name or look him up.
Old Jan 6, 2008 | 07:11 AM
mantodou's Avatar
mantodou
i put fatboy rear solid on my 01 lowrider,,,love the look
[IMG]local://upfiles/38431/CD8798B0170443F88B9148F7B9DA6B0A.jpg[/IMG]
Old Jan 6, 2008 | 07:24 AM
Trotter's Avatar
Trotter
I'll have a solid Chrome rear ( see sig pic ) 17 X 5 1/2 in a few weeks... I just orderedthese....
[IMG]local://upfiles/24219/674F0840180E44D7AB6A2C7985D6D590.jpg[/IMG]
Old Jan 6, 2008 | 07:31 AM
Psycho's Avatar
Psycho
Trotter, is the solid 17 inch rear on the softails like the deuce a solid bolt up to the dyna rear? Axle? Spacing?
That is one nice looking bike, btw. I really looked hard at that same ride when I bought the wg, but the balanced engine just didn't do it for me. Still lust after them when they go by though, but just can't get past the balanced part.
