Transmission Seepage
Old Jan 12, 2008 | 02:56 AM
Koppster's Avatar
Koppster
Default Transmission Seepage
Experts & Smart Ones,
Is this a problem or just part of doing business? Bike has 500 miles on it.
Thanks,
Rick
[IMG]local://upfiles/48659/9FF397314DB146B3A59623DD48CE0A84.jpg[/IMG]
Old Jan 12, 2008 | 03:40 AM
Black Bob's Avatar
Black Bob
Default RE: Transmission Seepage
I have about 6700 km on mine without any leaks, seepage, etc. I think a few small leaks would have been accepted a few years ago but with modern machining, quality control, etc. you shouldn't normally experience a problem like yours. I'd suggest you take it to the dealer.
[/align]
Old Jan 12, 2008 | 04:53 AM
jmpancoast's Avatar
jmpancoast
I have the same thing on mine with about 9500 miles. I am treating it as business as usual. Thing runs so good, I hate the thought of taking it to the dealer to have it pulled down and fixed.
I keepthinking of having a hangnail and the only way to have it removed is to go to a proctologist.
Old Jan 12, 2008 | 05:51 AM
Trotter's Avatar
Trotter
Mostallseep a little there .... The dealer has a clear silicone that will seal it up ... You'll notice it on the silver cases more than the black.....
Old Jan 12, 2008 | 05:53 AM
Critter174's Avatar
Critter174
this has been talked about many times if you try the search, but as i have read they is not nothing there fluid wise bud as i believe it was MUD posted before a rag and a little bit of cleaner and it wipes right off i used a little bit of break cleaner on it and wipe off .
Old Jan 12, 2008 | 05:56 AM
Critter174's Avatar
Critter174
hey trotter did you get the last few pms tried to email you also.
Old Jan 12, 2008 | 06:15 AM
Trotter's Avatar
Trotter
No... Try to PM Me....
Old Jan 12, 2008 | 06:37 AM
Critter174's Avatar
Critter174
sentsorry off topic back to the scheduled programing.
Old Jan 12, 2008 | 07:32 AM
DougsDyna's Avatar
DougsDyna
My understanding is that is not oil, but actually a form of corrosion due to the direct mating of aluminum to aluminum(???)
WD40 (or similar) and a rag takes it right off. I have seen post here from guys with older TC motors asking the same question.
After my 06 tranny was repaired the black spot shows up in a different spot on the seem, but still there. If you don't want the hassle of wiping it off, just don't ride
DougJ
Old Jan 12, 2008 | 11:37 AM
Sarge4life's Avatar
Sarge4life
It is definitely Par for the course. It isn't really a leak as no fluid is coming out; it is more like diffusion. It is totally harmless.
Blackfly
Sep 10, 2013 07:14 PM
TXSasquatch
Jul 28, 2012 06:42 PM
chief1600
Jun 16, 2012 03:04 AM
Mark g
Oct 11, 2007 04:39 AM
wnogood
Jun 15, 2006 11:36 PM
