V-Rod frontend on 06 Dyna, Help!
Old Jan 28, 2008 | 08:29 AM
Jay Risk's Avatar
Jay Risk
Default RE: V-Rod frontend on 06 Dyna, Help!
Chandler, could you elaborate on what you said about using the inner tubes from the WideGlide? If the V-rod lowers are 1/2" shorter than the Street Bob's, how do you compensate for that loss in overall length? What would be involved in using the WideGlide inner tubes? Jay
Old Jan 28, 2008 | 03:15 PM
woodreaux's Avatar
woodreaux
Hey Tomato,
Great job.
You did what I've been wanting to do for a long time.
About the Race Tech springs; did you use the V-ROD kit?
Old Jan 28, 2008 | 06:33 PM
2002fxdp's Avatar
2002fxdp
ORIGINAL: tomato
Ihave the V-Rod lowers (kept the 06 Street Bob upper forks and trips), but I kept the Dyna wheel - it has the mounting point for the second disk. Be careful, as the V-Rod internals are way stiffer than the Dyna. Ended up putting in Racetech Springs and valving to get the ride right. Now it is perfect. The braking difference is extreme - way better now.
<a href="http://s116.photobucket.com/albums/o...urrent=HD2.jpg" target="_blank"><img src="http://i116.photobucket.com/albums/o20/tomato03/HD2.jpg" border="0" alt="Photobucket"></a>
<a href="http://s116.photobucket.com/albums/o...urrent=HD1.jpg" target="_blank"><img src="http://i116.photobucket.com/albums/o20/tomato03/HD1.jpg" border="0" alt="Photobucket"></a>
<a href="http://s116.photobucket.com/albums/o...rrent=Dyna.jpg" target="_blank"><img src="http://i116.photobucket.com/albums/o...ato03/Dyna.jpg" border="0" alt="Photobucket"></a>
bike looks real nice....always a fan of the dual disc
Old Jan 30, 2008 | 07:58 PM
tomato's Avatar
tomato
Thanks guys. Yes, the V-Rod adjustable kit.
Old Jan 30, 2008 | 11:32 PM
DougsDyna's Avatar
DougsDyna
ORIGINAL: JRK5892
Japan i think that he just swapped the lower leg on one side so that he could run the duel brakes... what about using the front end from aFt bob... ... if you just pull the forks and lower sliders they should bolt right up... boom... duel disks... i have been wrong before though... it was a tuesday i will never forget it
I know what you mean............. It was a Tuesday when I was in the wrong place, at the wrong time...... I will never forget it.
DugJ
123easypay
Dyna Parts
Feb 16, 2012 03:35 PM
Dan B
Sep 9, 2008 09:57 PM
Spanish Flyer
Jan 7, 2008 02:45 PM
Cynic
Jun 19, 2007 07:23 AM
bobcowan
Jun 18, 2006 04:07 PM
