V-Rod frontend on 06 Dyna, Help!
Old Jan 25, 2008 | 08:36 AM
HD Top Fuel's Avatar
HD Top Fuel
2nd Gear
Default V-Rod frontend on 06 Dyna, Help!
Has anyone seen or done this swap? I'd like to have the duel front breaks and this looks like the easiest and cheapest way. I have a FLH master cylinder and havefound a crashed 03 V-Rod for the donor Forks and wheel. Both have 49mm forks so how hard can the swap be?
Old Jan 25, 2008 | 08:43 AM
chandler's Avatar
chandler
Default RE: V-Rod frontend on 06 Dyna, Help!
The only issue is that the v-rod fork assemblies are shorter by someting like 2" than the standard dyna assemblies. If the lower ride height is an issue the inner tubes from a wide glide should put you where you need to be. I haven't made the change, but I've beed doing my research.
Old Jan 25, 2008 | 08:49 AM
hmmr's Avatar
hmmr
ORIGINAL: HD Top Fuel
[sm=signs003.gif]
are you just thinking of putting the vrod tubes into your triple trees? or the entire front end?
the thread title refers to a front end swap while this comment suggest a fork change.
Old Jan 25, 2008 | 08:50 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Which dyna model?
Old Jan 25, 2008 | 08:53 AM
hmmr's Avatar
hmmr
ORIGINAL: KBFXDLI
Which dyna model?
i was wondering that too, which dyna has a 49mm single disc front end?
Old Jan 25, 2008 | 08:59 AM
KBFXDLI's Avatar
KBFXDLI
ORIGINAL: hmmr
ORIGINAL: KBFXDLI
Which dyna model?
If he is swapping the whole front end the rake is a big consideration also. Kinda like putting a cat's head on your dog.........
Old Jan 25, 2008 | 09:51 AM
jmpancoast's Avatar
jmpancoast
A forum member has successfully done this. I ran into his post in a thread about better brakes options on the Dynas. Do a search and you should be able to find him.
Old Jan 25, 2008 | 10:03 AM
JRK5892's Avatar
JRK5892
Japan i think that he just swapped the lower leg on one side so that he could run the duel brakes... what about using the front end from aFt bob... ... if you just pull the forks and lower sliders they should bolt right up... boom... duel disks... i have been wrong before though... it was a tuesday i will never forget it
Old Jan 25, 2008 | 10:44 AM
jmpancoast's Avatar
jmpancoast
The Fat Bobs have a 25mm front axle.
Here's a pic of a Skinny Bob with the dual discs.
Old Jan 25, 2008 | 10:54 AM
hmmr's Avatar
hmmr
don't forget the proper master cylinder for dual calipers
