Standard or Heavy
Old Jan 30, 2008 | 12:50 PM
dklozik's Avatar
dklozik
Default RE: Standard or Heavy
Not trying to hijack a thread here but I have a question. Chip, how much lower did the 11" make your bob and do you know the stock shock length ? Thanks.
Old Jan 30, 2008 | 01:10 PM
Chipstah's Avatar
Chipstah
412 11" shocks will lower the bike almost 1" I suspect, but never measured it. I have a 29" inseam (although 6' tall) and needed to get both my feet flat on the ground. Now no problem, plus the contour of front of the Mustang seat helps too. Haven't scraped the pegs yet either.
Pretty sure the stock shocks on the street bob are 12".
Old Jan 30, 2008 | 01:22 PM
Dawg Rider's Avatar
Dawg Rider
Did you go with heavier fork oil? I have progressive fork springs already, but I'm condsidering using heavier oil like some on here have mentioned.
Old Jan 30, 2008 | 01:36 PM
Chipstah's Avatar
Chipstah
yes, Amsoil.
Old Jan 30, 2008 | 03:09 PM
SPECIAL ED's Avatar
SPECIAL ED
What weight oil? I used 15wt on my SV with Racetech springs and emulators but that's apples and oranges.Progressive front prings and heavier oil will be my next mods.
Old Jan 30, 2008 | 03:17 PM
Chipstah's Avatar
Chipstah
It was a while ago and got it from my indy on his recommendation but don't exactly remember - might have been the Amsoil #10 but wouldn't swear to it. Might want to check with Progressive for their recommendation.
Old Jan 30, 2008 | 04:35 PM
kzad's Avatar
kzad
1"shorter shocks would lower the bike 1" if they were attached to the axle, andmounted straight up and down. Because they are attached to the swingarm with the pivot point in front and the axle behind, and mounted at an angle, it results in more than 1" lower seat height. The Works Performance web site has an application chart...according toit 3/4 inchshorter shocks result in a 1-1/4 lower ride height on an '06 FXDL....judging by that a 1"shorter shock would drop you around 1 5/8"
Old Jan 30, 2008 | 05:06 PM
ode sku's Avatar
ode sku
hd is what i run im 165 and like them alot easily adjusted for 2-up with wifey
Old Jan 30, 2008 | 05:23 PM
TOMMAY's Avatar
TOMMAY
ORIGINAL: kzad
Ditto on that,heavy duties on the lightest setting really slam the bike,the lip of the fender is below the bead on the tire,looks great and rides plenty firm but handles great. You will become adept at dodgin potholes after a while to avoid braking your bike.
Keep in mind that the lightest settin will lower the bike the most. The more preload the higher the bike will sit.
Good Luck
Tom
Old Jan 30, 2008 | 10:16 PM
PsTaN's Avatar
PsTaN
Good thread .... very informative. When I lowered my bike I went with the H-D Shocks knowing they wouldnt really slam the bike/perform better .... they would lower 1" and wereeasily had so I got them. I love the look of the 11", but have always worried about the trade-off they would seem to force one into .... pre-load them to ball bustin' firm or unload them and worry over breakin' stuff that dont need breakin'.
I ride with the H-D lows on pre-load setting 4 and the shocks are exactly 11.5" on the bolt centers with 1" of tire showing between the wheel and bottom of the fender. I think a Progressive 11.5" shock would lower my bike more? .... I certainly feel they would perform better based on the opinions here.
I'm really looking forward to seeing someone put some 11.5" Progressive 418/440 on a bike so we can get a close look at exactly the stance they produce. I do believe that will be the point at which I make up my mind (11 or 11.5)and get new shocks to enjoy the benefits of the better handling and ride that all you guys speak of.
PsTaN
Brad&Mar
Apr 27, 2013 09:01 AM
mikeo33y
Jan 2, 2013 10:58 PM
Yates
Touring Parts
Feb 8, 2012 09:04 AM
Cpitch
Sep 17, 2009 05:54 PM
KooeL49
Feb 12, 2008 03:20 PM
