PClll Question about O2 eliminator
Old Feb 2, 2008 | 05:14 PM
Graduate's Avatar
Graduate
Default PClll Question about O2 eliminator
I bought all the stuff for stage1 upgrade inluding V&H BSS, PClll and, KN3909. The PClll has O2 eliminators and no longer needs them so I bought the plugs that go in the bungs on the pipes. What do I do with the wires that the O2 sensors plugged into?Do I just cover them with deox compound,tape them up, and tuck them away?Thought i would leave the sensors in the old pipes in case I ever sold the bike or needed to put them back on for some reason. Thanks
Old Feb 2, 2008 | 05:18 PM
fj4069's Avatar
fj4069
Default RE: PClll Question about O2 eliminator
i left the front primary o2 plug in the holder and tucked the rear back into the battery box area.problem solved.
Old Feb 2, 2008 | 05:36 PM
Arcane's Avatar
Arcane
I can be wrong but I think that you will need to use those cables, don’t the o2 sensor eliminators plug in to the cables that the o2 sensors were using?
Arcane
Old Feb 2, 2008 | 05:42 PM
Graduate's Avatar
Graduate
I guess that's my question
Old Feb 2, 2008 | 05:55 PM
Arcane's Avatar
Arcane
You can leave the o2 sensors or remove them and screw caps into the bungs. While I ran the PC III I left the sensors in place. Just disconnect the o2 sensors and wire tie the cable on the o2 sensors so that it will not flop around. You will use the o2 eliminators to cap the cables going to the ECM.
Arcane
Old Feb 2, 2008 | 06:06 PM
Graduate's Avatar
Graduate
That's the answer I was looking for. Thank you
Old Feb 2, 2008 | 06:12 PM
Smiley51's Avatar
Smiley51
I disconnected mine at both ends and removed wires. I also used the crush washers off the 02 sensors when I plugged the bungs.
Smiley
Old Feb 2, 2008 | 07:51 PM
hddave2's Avatar
hddave2
im going to buy a pc111 with o2 elem. for my 06sg, so if i understand right ,i wont be using the o2 sensors that are in my v&h short shots? i also thought i would have to use the sensors
Old Feb 3, 2008 | 12:14 AM
Tat2u's Avatar
Tat2u
+1 to what smiley did
profinish
Apr 22, 2008 09:34 PM
bikergar
Mar 26, 2008 05:54 PM
Nyter
33
Jul 28, 2007 07:29 AM
damadman
Jul 3, 2007 11:58 AM
twilliams
Exhaust System Topics
Jun 26, 2007 06:27 PM
