not returning to first gear
Old Feb 9, 2008 | 05:50 AM
cholmes's Avatar
cholmes
Default not returning to first gear
I was able to take my 08 fxdc out for a ride recently and found something strange: When coming to a stop and slowing down through the gears I found I was still in third gear after stopping but it was acting like I was in first. I still needed to down gear to first. This happened several times. Any ideas?
Old Feb 9, 2008 | 06:54 AM
glebo's Avatar
glebo
Default RE: not returning to first gear
ORIGINAL: cholmes
when I had my dyna, after about 10k miles on it it started doing that. It would not go down to first when coming to a stop. I had to let the clutch out a bit while pressing down on the shifter to get it into first.
The problem...I'm not really sure it wouldn't do it all the time, seemed like it did it mostly when cold. Recheck your clutch adjustment and change your primary and tranny fluids. I think the manual states that if your primary is slightly overfull, it will cause the clutch to drag.
Has mine stopped..I don't know I traded it at 15,5k for a Road King.
Hope this helps. Good luck
Old Feb 9, 2008 | 10:57 AM
williamfrog's Avatar
williamfrog
Make sure you lift your foot all the way off the shifter , I went from a Sportster to a Dyna and had that problem , trans down shifted different .
Old Feb 9, 2008 | 11:34 AM
cholmes's Avatar
cholmes
Williamfrog - That sounds like the problem. I think I am a little heavy footed when shifting. Thanks I will try lightening up.
cheezy97
Sep 17, 2011 03:48 PM
VTwinJaxFL
Sep 27, 2010 12:09 AM
mankx
Aug 11, 2008 12:34 PM
sdkimes
May 22, 2008 11:44 PM
mfiumano
Sep 17, 2006 01:07 PM
