Found something on my front forks
Old Feb 9, 2008 | 08:49 PM
TMace's Avatar
TMace
Default Found something on my front forks
Was replacing my front tire today and with the axle removed I noticed that at the bottom of my forks there is an allen head bolt in each one. Appears to be around 3/8ths in size. Could this be the drain for the fork oil??? Manual says nothing about them. Says to drain fork oil to remove forks and disassemble. Others on this site have said same, that they did away with the drains in 06. Could mine have 05 forks??? Or does this hold the bottom of some spring???
Old Feb 9, 2008 | 09:17 PM
mud's Avatar
mud
Default RE: Found something on my front forks
ORIGINAL: TMace
TM, don't remove that 12mm bolt unless you want to disassemble the fork pipes.
No drain plug on the 06 up Dynas.
mud
Old Feb 9, 2008 | 10:41 PM
DougsDyna's Avatar
DougsDyna
ORIGINAL: mudpuddle
ORIGINAL: TMace
mud
Oh no!![sm=oopssign.gif] Really glad he asked that question.
DougJ
Old Feb 10, 2008 | 12:12 AM
FastHarley's Avatar
FastHarley
Former Sponsor
ORIGINAL: mudpuddle
ORIGINAL: TMace
mud
Mudd, are you sure it is a 12mm? The # 6 keeps on poping up. Give a call. Just did (almost done) a conversion of a 67 Electraglide Pan/Shovel front end to a 04 FL front end to get the disk brakes. Busy for 3 days now.
Old Feb 10, 2008 | 02:46 AM
arnold's Avatar
arnold
ORIGINAL: mudpuddle
ORIGINAL: TMace
mud
Could you clarify fore I break something? I was told on here and from my dealer thats how you drain front fork oil
Old Feb 10, 2008 | 06:43 AM
Psycho's Avatar
Psycho
ORIGINAL: arnold
ORIGINAL: mudpuddle
ORIGINAL: TMace
mud
It holds the dooflatchy in the bottom of the thingamajig. Don't take it out unless you plan on completely dissasembling the fork tube assembly.
Oh, and find a new dealer. ASAP.
Old Feb 10, 2008 | 09:52 AM
mud's Avatar
mud
ORIGINAL: FastHarley
ORIGINAL: mudpuddle
mud
Howard, I should have justsaid -don't remove that bolt.
12mm isthe wrench size on the Dyna. Metric I don't get it all.
I'll try to give you a call later.
I wanna hear about that front end conversion.
mud
mud's Avatar
mud
ORIGINAL: arnold
ORIGINAL: mudpuddle
mud
Arnold,removing the boltwon't break anything,
but I woukd call that dealer again for clarification.
We have discussed this before when you were suggesting
using a syringe to inject new oil thru the bottom hole.
mud
mud's Avatar
mud
ORIGINAL: Psycho
ORIGINAL: arnold
Psych, you build that motor this winter???
Bolt #30 holds part #23, the dooflatchy,
in part #26, the thingamajig.
mud
Old Feb 10, 2008 | 10:15 AM
arnold's Avatar
arnold
ORIGINAL: mudpuddle
ORIGINAL: arnold
ORIGINAL: mudpuddle
mud
mud
Thanks for the pic/breakdown Mud. I havent gotten round to draining oil yet, (Sigh of relief) But I DID actually call the dealer and they told me the bolt in the middle drains your oil, no sweat. Im not doing nuthin till I talk to another dealer, Im going in for 5000 service this week, dif dealer, I will ask for clarification. If thats what it looks like I cant believe the dealer shop said to drain w that bolt.
