Transmission Drain Stripped
Old Feb 26, 2008 | 09:02 AM
mud's Avatar
mud
Default RE: Transmission Drain Stripped
Rick, the frame doesn't block any of the bolts.
There is a wire loom that has to be moved.
Be careful about hogging it out with an oversized tapper.
Don't screw it up to a point that will be
beyond the helicoil's ability to repair it.
Thought you said the teflon taped plug was torqued in there snug.
mud
ORIGINAL: Koppster
Mud,
I gave it a close look last night and there is only one screw blocked by the frame (right side). I believe I can get to it with a long ball-end allen stock. I
'm going to stop in at Napa and get an oversize self-tapper tonight just to get me through the next week or two and as soon as I get a chance, I'll pull the pan and come see you. Better to have it off I think, shavings and all that.
Big Thanks Amigo,
Rick
Old Feb 26, 2008 | 09:32 AM
Koppster's Avatar
Koppster
Mud,
The plug with teflon did torque (the first time); however, I filled the tranny with oil and drove it for about five minutes to flush the system.
After I drained it, the plug would not tighten, period. I even tried a brand new plug. It will screw in but won't tighten.
Rick
Old Feb 26, 2008 | 08:46 PM
SPECIAL ED's Avatar
SPECIAL ED
They make a rubber expanding plug thing specifically for this type of thing for cars maybe you can find one that fits.If not you can make one pretty easily I know this sounds mickey mouse but it works great; take a piece of rubber tubing just big enough to fit in the hole, run a smaller bolt through the center with a washer and a nut.Tighten it finger tight push it into the hole and tighten it up a couple turns,leave enough of it sticking out that you can get hold of it with pliers when you need to drain it.Like I said I know it sounds funky but I ran a set up like this on my last dirt bike for about 5 years, it never fell out,never leaked a drop of oil.
Old Mar 2, 2008 | 11:25 PM
Halfbuck's Avatar
Halfbuck
Koppster,
I replied to your PM, but thought I'd also post in the thread (for reference):
Ibought the plug at an Advance Auto Parts store, I think. Autozone, NAPA, etc. should have them. I just asked for an oversized plug for a stripped out drain, and they knew just what I needed. They had a rack full, so I assume that it's a pretty common occurrence.
The plug has an o-ring, but it's moreplastic than rubber. It's been sealing fine though. I don't believe that the one that I have has a magnet, but I've seen the ones that do.
We threaded the plug in and out a few times, then flushed through the drain a few times to be sure that we got the shavings out.
I was using someone else's torque wrench. No clicks like mine. When I first felt that free spin....Arrgghh!Visions ofbills from the Harley shop flashed through my mind. My father-in-law was helping me, though and he'd seen it before.
Good luck!
johnica
Aug 30, 2012 11:11 PM
PPBART
Mar 6, 2010 08:58 PM
m.breen
Jul 1, 2007 11:11 AM
petemac
May 19, 2007 06:39 PM
tprkt
EVO
Oct 17, 2006 08:13 PM
