Rear Fender Options for 08 Bob
Old Mar 4, 2008 | 04:35 PM
UNCLE PAT's Avatar
UNCLE PAT
Default Rear Fender Options for 08 Bob
I'd like a sportier look....the stocker is too long.....any options?? custom?? I could care less about re-painting to the denim red....would a wide glide fender fit??? thanks...
Old Mar 4, 2008 | 04:40 PM
dyna rider's Avatar
dyna rider
Default RE: Rear Fender Options for 08 Bob
I had a friend who put a Wide Glide fender on a 07 Street Bob. I would think the 08 would be the same but am not sure.
Old Mar 4, 2008 | 04:49 PM
UNCLE PAT's Avatar
UNCLE PAT
Thanks bro..
Old Mar 4, 2008 | 04:53 PM
hd_sob's Avatar
hd_sob
I put a bobtail on my '06...
Old Mar 4, 2008 | 04:55 PM
UNCLE PAT's Avatar
UNCLE PAT
just called HD....fatbob and mounting kit...painited 600 bucks....guess you wanna' play...you're gonna' play.
Old Mar 4, 2008 | 05:01 PM
motox285's Avatar
motox285
i went with a gunslinger 8.5 from jessejames 143.00 shipped off of ebay then i had to spray it. gives a nice clean look
Old Mar 4, 2008 | 05:54 PM
hd_sob's Avatar
hd_sob
ORIGINAL: UNCLE PAT
Dude, there should be a color-matched bobtail fender listed in the catalog for your model. There was for my '06, anyway. You will need the fender itself and the mounting kit which contains everything else necessary to make the switch.
When you say 'fatbob', do you mean the fender off a new Fatbob or were referring to a run-of-the-mill bobtail fender from a Wide Glide (like mine)?
Perhaps I have misinterpreted your post(s)...
Old Mar 4, 2008 | 07:09 PM
UNCLE PAT's Avatar
UNCLE PAT
ORIGINAL: hd_sob
ORIGINAL: UNCLE PAT
no bro...I meant 2008 Fatbob rear fender.....I called and it's about 600 for all you said....painted to match....
Thanks for the help....
Old Mar 4, 2008 | 07:18 PM
hd_sob's Avatar
hd_sob
ok then in that case, unless you are in love with the fatbob fender, check the catalog or parts dude at local stealer and see if there is still a color-matched 'wide glide type' bobtail fender for your scoot. i think mine, in black denim, was ~$300, about a year ago. 'course, the install kit was another couple hundred, if i remember correctly...
Old Mar 4, 2008 | 07:36 PM
SPECIAL ED's Avatar
SPECIAL ED
It's a different look but you can chop the one you have for next to nothing.Nevermind I thought you had a Street Bob, still you can get a used Street Bob or Dyna fender and chop the hell out of it for allot less than $600.
