180 tire
Old Mar 7, 2008 | 06:40 AM
  #31
hddave2's Avatar
hddave2
Default RE: 180 tire
does the Metzeler tire run smaller than the dunlop even though they say 180 just like the dunlop
Old Mar 7, 2008 | 06:45 AM
  #32
jsbridgew's Avatar
jsbridgew
no, the kit is useless....the kit has nothing to do with the rim....it's the bead on the dunlop tire....it's different than other 180s.... this issue has been beat to death over the past 2 years....that's not to say that an Avon, Metz, or any other 180 can't be used on the 4.5 rim, they can.... but it's risky, so i've been told
Old Mar 7, 2008 | 07:31 AM
  #33
2007fxdc's Avatar
2007fxdc
ORIGINAL: 1nuckenfut
I put the kit on my bike last year. It comes with 2 new interior fender plates. There is kind of a hook at the end of the plates that holds the signal wires in a different position. But the main reason for the kit is it comes with 2-$25 a piece allen head bolts for the rear strut-signal bolt. The allen head does not stick out as far into the tire as the stock hex head bolt. The kit costs so much due to the technology and research for HD to figure out that allen bolts don't stick out as far as hex bolts.
I've been told this but apparently HD doesn't recognize this as fact that, if you have the detachable sideplate hardware installed, you don't need this kit because you already have different fender strut backplates and the signal relocation strut bolts are different as well. I know for a fact I have no clearance issues with wiring under my fender and I do have the detachable hardware set. I'm not paying for the "kit". I will be gettin that tire though.
Old Mar 7, 2008 | 08:16 AM
  #34
jsbridgew's Avatar
jsbridgew
that's what i'm doing 2007fxdc.... signal relocation kit for saddles.... issue solved for clearance... no kit needed
Old Mar 7, 2008 | 11:20 AM
  #35
Dynaflyer's Avatar
Dynaflyer
I agree, The kit is useless!
I did theNON detatchable sideplates and have no issues at all. Wires are tucked in just fine and the Button head bolts Create a low profile.
I just posted a pic of the kit because 07 bobber wanted to see what it looked like. No Big Deal...........
Detatchable or rigid sideplates do not need any mods to fit the SE 180.
FWIW, The Metzeler tech said the tire I was interested in buying [ 170/60/17 ] was 8mm WIDER Than the Stock Dunlop 160/70/17.
He was WRONG!!!! It's the other way around. [:@]
Old Mar 7, 2008 | 11:24 AM
  #36
Dynaflyer's Avatar
Dynaflyer
ORIGINAL: hddave2
Not sure about the 180 but if you are considering a Metz 170...
YES!!!! I have a Metz 170/60/17 and it is 8mm, 1/4" smaller than the stock 160/70/17
Old Mar 7, 2008 | 11:49 AM
  #37
hddave2's Avatar
hddave2
well i wont be getting the metz 180..if its smaller..i guess im just gonna price a new se 180 tire from the dealer and see if i can afford to get them to remove and install new tire.. any ideas what i get as far as price
Old Mar 7, 2008 | 12:20 PM
  #38
Dynaflyer's Avatar
Dynaflyer
ORIGINAL: hddave2
Here is a link to Zanotti. Plug in Part number 43197-04A $155.50 Less shipping.
Not sure what shipping would be, what harley charges for this or how much to mount and balance through your Indy or dealer.
https://www.zanottimotor.com/shopping/pLookUp.php
Old Mar 7, 2008 | 01:47 PM
  #39
domenicp7's Avatar
domenicp7
The stealer install requires a kit. It is a liablity issue on their part. I was told. I didn't make a big issue on it. I would be rather safe than sorry when it comes to $70.00 and my life.
Old Mar 7, 2008 | 01:49 PM
  #40
SkyRider's Avatar
SkyRider
ORIGINAL: domenicp7
well at least they got the sale....
