S&S Quick Set-Up Kit
Old Mar 9, 2008 | 07:51 PM
pennetta's Avatar
pennetta
Default RE: S&S Quick Set-Up Kit
I was looking for something better sounding than stock, how did the S&S sound?
Old Mar 10, 2008 | 01:03 AM
mfuchs2004's Avatar
mfuchs2004
I know Trotter is right in any case. I might consider such a kit, but I'd never put the damn thing on my bike without a good Dyno tune. That won't stop me from picking away at the AIM claim though. Can't help it - I'm stuck on it like a hound dog on a ham bone. I want to know how they support this claim. I think they've got meds for this, but my doc is out of town til Tuesday, LOL
Another thing I'm stuck on is crying myself to sleep every night cause he's on the opposite coast from me. I'm Jonesin' for one of his $199 dyno tunes! If there's not a line of HDF members out his door each day, I'd be shocked!
Old Mar 14, 2008 | 11:40 PM
man4mopar's Avatar
man4mopar
The stock ecm on 06 and up dynas, 07 up rest of harleys are a closed loop narrow band set up as many know. It also has some open loop areas in the mapping. I have no doubt the stock ECM can calibrate a Air filter swap and exhaust change no problem in the closed loop sections. It would set a code quickly if it couldn't. It is the open loop areas I would be curious to see. The ECM does calcs off of the closed loop info and applies it to the open loop mapping so some correction would occur in the open loop areas but there is nothing monitoring correctness. So knowing that I would want to run a sniffer while riding to check AFR's.
Trotter and others feel that a 14.7:1 ratio is too lean. If one wants out of that mixture in a lot of the map you would needa fuel management system or trick set upeven on a stock bike.
Old Nov 21, 2008 | 04:45 PM
pennetta's Avatar
pennetta
This is an old thread, but I installed the S&S Quick Setup kit and did not remap the ECU. After riding the whole season I can say it was well worth the money. It breaths better on top and sounds fantastic. I just changed the spark plugs and they were burning perfectly.
Wardog86
Mar 28, 2013 01:07 PM
Classic3
Oct 6, 2010 01:54 AM
bmugharley
Exhaust System Topics
Sep 11, 2009 08:49 PM
pwworth
Dec 22, 2008 03:14 PM
Grunt66
Feb 22, 2008 05:10 PM
