turn signal relocation
Old Mar 10, 2008 | 08:58 AM
so165's Avatar
so165
Default turn signal relocation
I have a detachable backrest on an 08 superglideand when Ibungee something down, two of my conection points are the turn signals, if I move the turn signals to the back(license plate) will I still have room enough to connect the bungees at the same point as I always have?
Old Mar 10, 2008 | 09:08 AM
Jaybob07's Avatar
Jaybob07
Default RE: turn signal relocation
Or you could just get smaller bungees. I normally strap my thermus with 2 small bungees from one side of the back rest to the other wraping around it in an "X".Have not had any problems with it.
Old Mar 10, 2008 | 01:58 PM
MikesWideGlide98's Avatar
MikesWideGlide98
Check the back of J&P cycles catalog, they have bungee connection tabs. You pull the bolt out, slip the bolt through these things and then put the bolt back on. They look good, i have never used them but always liked the idea.
seadogmike
Jul 31, 2018 08:34 PM
apeluv
Oct 23, 2015 06:35 PM
tc88hog
Dec 15, 2008 11:36 PM
sr71gn
Jul 12, 2008 04:09 PM
geo10
Jul 29, 2006 04:37 PM
