Big Radius baffles
Old Mar 10, 2008 | 03:51 PM
captn harley's Avatar
captn harley
6th Gear
Default Big Radius baffles
Installed Big Radius on my 02 wide glide last year,thinking about removing the baffles but can't get them out of front pipe. Any sugg.??? Or should I just leave them in ??
Old Mar 10, 2008 | 05:33 PM
1nuckenfut's Avatar
1nuckenfut
Default RE: Big Radius baffles
I had the same problem with mine when I changed out the baffles. Remove thebolt that holds the baffle in place and thread back into the baffle from the inside of the pipe. Don't thread it far enough to go outside the baffle. Next you hook something onto the bolt sticking out and start pulling. I clamped onto it with a pair of vice grips and starting tapping the plier ends with a hammer and after a few hits it fell out.
As for should you do it. Not a good idea to run open pipes. Screws up motor back pressure that can lead to damage.If you want better sound check out Big City Thunder baffles.
Old Mar 10, 2008 | 07:16 PM
captn harley
6th Gear
Thanks, I'll check'em out
TxChris
Exhaust System Topics
Feb 8, 2016 09:06 PM
coronerrpm
Aug 12, 2010 12:26 AM
frist44
May 12, 2010 07:45 PM
Gutter Man
May 24, 2009 03:43 PM
fixxr
Feb 5, 2009 02:55 PM
