thanks Ron and Mud and everyone else who has offered ideas. I'll bleed the air out, recheck the oil level and cut the spacer a little to reduce the preload. I'll keep you posted on progress.
my stock 08 Super GLide does the same thing. i had the dealer check it and they installed the new washer fromHD. better but not fixed. i checked the 'fall away' per the maintenance manual and torqued the neck nut to specs - that got most of it but i can still get it to 'clunk'
good luck and if you get it 100% let us know what you did.
Mud, if my fluid dynamics is still up to snuff , the 3 oz's of extra fluid probably translates to the WG legs being about 1.75" longer than the other Dyna's. Because the fluid level measurement is from the top ofthe tube collapsed. If thats the case then I agree with why there wouldnt be a problem with guys who put it in to the specs (incorrect) outlined in 06 manual.
Muddy, I went back and edited in the 2007 manual.
Like I said I wondered about the values given for the volumes,
but, I never go by the volume,
always measure distance from the top of the fork tube.
Thanks for bringing this discrepancy to light.
I want to know what other misprints are in the 06 manual?????????????
