Stage 1 and Stage 2 refers to performance modifications. There really isn't a fixed definition. Typically a stage one would be free flowing pipes and improved air intake with appropriate rejetting or maping. Stage 2 would be more radical - possible cams and other mods. Check the link above for some good information on th subject.
I'm a bit of a newbie myself, so I'm sure someone will correct me on this, but a Stage 1 upgrade is generally when you change out the stock mufflers for non-choked-down mufllers (for instance Screamin' Eagle IIs), change out the air breather for one with a more generous input (more air out requires more air in), and finally rejetting and/or adjusting the carburator (or EFI code adjustment) to make the fuel mixture leaner.
Okay, now all you experienced guys, tear my answer apart and explain Stage II (I'd like to know that, myself). [sm=helpout.gif]
